#11 | |
![]() Quote:
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car" 408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's -2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's - Two 87 turbo'd/targa top'd supras (*Under Construction*) ![]() |
#12 | |
![]() Quote:
/smartassness
#13 | |
![]() Quote:
#14 |
IT FINALLY RUNS! Replaced the igniter with one off my parts car and bam, runs like a champ. Still got the MAF code and its a little low on power but its running is the main thing. About to do a compression check on all cylinders and seewhere that stands. Also have some rod knock. Thought maybe it was something loose but its defiantly rod knock. Im going to track down a MAF and see if I can rid of that code and then Ill start form there. Going to pull the motor from the donor car this weekend and start getting it ready to be swapped when this one dies. I did shim the waste gate .022 so the boost was right at 7psi. I dont guess ill up the boost until I get the new motor ready. But thankfully she's running.
#15 |
Just finished the compression check and heres what I got:
1- 130psi 2- 130psi 3- 130psi 4- 130psi 5- 136psi 6- 134psi Sound about right? Car was still hot from just getting back from driving it. 142psi should be perfect so 4 of them are getting close! I also put my NGK's back in there and now it has a miss under load. So looks like tommorow ill be swapping the NGK's back out. Always something!
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car" 408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's -2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's - Two 87 turbo'd/targa top'd supras (*Under Construction*) ![]() Last edited by Z'mnypit; 05-03-2007 at 01:15 AM. |
#16 |
Those numbers are a little low, minimum cylinder pressure is 128psi on turbo models so you are pushing it to the limit.
Unfortunatly, I was right about the rod knock. Definately from running the engine with all the coolant in it. Not saying you did it. I'm sure the retard that you bought it from drove it like that for awhile. Glad you got it running. I knew it was either the coil packs, MAF or igniter that got soaked and took a dump. Keep us posted! |
#17 | |
![]() Quote:
That and it sat filled with antifreeze and oil mixed for a long time. Still got replace the maf. Its still got that code. Im just glad the issue is resolved, I was about to go nuts.
#18 | |
![]() Quote:
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#19 |
You shouldn't hose a supra engine down, the main reason being that there are 2 different types of metal parented together at the head gasket.
I think this is why they were giving you a hard time. But I could be wrong. |
#20 |
Alright guys I know its been awhile since Ive been back here. Ive been fighting with this stupid car for the past week with no luck. Heres my issue now: Got rid of all the SES lights except for the 52 (knock sensor) I dont know whats up with this code, Ive rewired the sensors and it still does it. Guess next Ill swap them out. The MAF is new, and all the other codes are gone. Now, it will start up fine, run fine but when the boost kicks in it will fall on its face. You literly have to let out of the gas watch the boost gauge drop then get back in the throttle to get it to move. As long as you dont go WOT or under a load its fine. But once you hit boost it nose dives. Ive checked every clamp, every pipe and I cant find any leaks. Ive checked the BPV and you cant blow through it at all. Ive backed the timing way off and all it did then was black smoke. So I know its getting the gas then. Im all out of options. I have a uncle who is a head mechanic at a local toyota dealership and was going to take him the car friday but hes in the hospital now so that puts a damper on that. Im open to any suggestions to try, Im on my last nerve with this car.
Thanks!
1988 Toyota Supra Turbo runs very rich need help | PhillyKorean | Non-Generation Specific Questions | 0 | 10-25-2008 03:28 PM |
1982 supra runs really rough when cold | tylertatum | Non-Generation Specific Questions | 0 | 10-04-2005 08:01 PM |
