I've notice for the past two weeks everytime i make a turn the low engine coolant light comes on buh i check the radiator and its full and the container that full too. took it to my friends dads machanic shop and they said prolly a bad sensor so dont worry. but ive been smelling somewhat of burnt rubber or something
Thanks for the help
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP Last edited by 88Tsupra; 05-03-2007 at 04:02 AM. |
Where is the smell coming from? Your vents? Is there white smoke coming from the exhaust?
The low coolant or "birdcage" light is coming on because you have an air pocket in your coolant system. Are you hearing a water fall??
None the less..., get a pair of ramps or park on a steep incline. Pop the hood and let the engine cool a bit. Take off the radiator cap. Start the car. Top it off. With distilled water and or coolant depending upon your mix. Check it every few minutes. keep topping it off. If you stand there and watch you will probably see small bubbles every little bit. Just keep topping it off, keep the nose elevated. This could take 15 minutes or two hours depends on you and your coolant system. This method is referred to as " burping " . Hope this helps. |
thanx...i get white smoke wen startin the car in the morning buh i let it warm up for about 10 mins
thanx supramacist ima try that with the help of my uncle maybe i can get the damn thing to stop it never did it before though as for hearing a water fall im not sure ima have to check and get back to that..i do hear somewhat of what can be called water splashing when it idles/sit still
88turbo targa-white original Pin Stripe custom intake-Tenzo filter.....Momo racing seats and steering wheel... apexi exhaust tip-custom 3" piping. Replaced with RSR GT II NGK plug and wires HID conversion head lights HKS Turbo Timer Type-1 (in black) Tial BOV BIC DDP |
The water fall noise kind of reminds me of a rain stick that you would see at coach house in the mall.
But if you hear liquid sloshing and it's from under the hood..., burping will solve it. I would seriously do mine and keep it on ramps in the morning till night fall and do some night driving. Let it run while it's elevated and check it every 15 minutes or so. The steeper the incline the shorter the process and the better results. If it doesn't stop it..., repeat the process until it does. I did mine like 3 times after I got it, I worked it 2 hours at a time. It finally filled up and emptied the air. I know one cat that spent 15 hours burping and finally achieved his goal. Don't overheat it while you are driving it with the warning light coming off and on. Doing that could lead to overheating, wich in turn will lead to a blown head gasket or BHG. |
#6 |
the low coolant light is not pointing towards the radiator
it's indicating that the coolant overflow bottle is low it's located in front by the driver side headlight looks like a windsheild washer bottle the light comes on because the fuild level is too low your coolant system is using/leaking water
#7 | |
![]() Quote:
1987 N/A Targa 5 speed no mods as yet |
#8 |
![]() Sorry, I couldn't resist!! |
#9 |
well today i made a left turn at like 5mph and the light stayed on..im getting a little scared here about the HG going on me..Thanx ihatehack. ima just get the 90arp bolts and the stock gasket. because im thinking of either selling it or gettin a new motor now. I know im gunna miss the supra if i do but i gotta wait till i get a job that can afford the supra
well i have some ishino headgasket that sells for 64bux it says its OEM replacement and some felpro HG for $99 Are those good prices for headgasket and brand..i See that Hack use felpro but i dont need n ething crazy just a simply replacement thank you again guys need this help badly
#10 |
ok i didnt wanan start another thread so ima just add to this one again
I did my compression test today and it read from 1-6 180 170 170 180 175 170 its strange to me that its around 10 psi apart buh its ok right now i got the low engine coolant still im just thinkin its a leak and yes i did the block test and it came back negative so i take it as the HG is good to go
Check Engine Light & Warning light on | Chomper | MKIV FAQ | 19 | 02-11-2011 12:51 PM |
Funky engine coolant issue | shirkinator | Non-Generation Specific Questions | 1 | 06-22-2009 08:37 AM |
Engine light and warning light on. | Chomper | MKIV Supra | 11 | 07-18-2008 11:44 AM |
Engine Light | Supra91_ishot | Non-Generation Specific Questions | 2 | 06-08-2005 12:37 PM |
1998 Supra Check Engine Light | SupraLady | Non-Generation Specific Questions | 2 | 12-15-2004 11:39 PM |
