Old 05-04-2007, 02:41 AM   #1
tone loc
tone loc's Avatar
Default clutch removal?
not sure how to take the clucth bolts off. i need to take them off to get the tranny off the engine right? tsrm says that you have to turn the crank pulley. how? the clucth turns when i try to unscrew it. thanks
Old 05-04-2007, 03:43 AM   #2
Supra2NR
Supra2NR's Avatar
you need a friend to counter the pulley turning
ot get a socket wrench (not sure how big the socket needed)
have it against so it wont spin when you try to take out the clutch
idk why you need to take out the clutch to take out the tranny
if i remember right, i put the clutch in the engine b4 i put the tranny
Old 05-04-2007, 03:44 AM   #3
supramacist
supramacist's Avatar
YA uhm, I pay toyota for that kind of headache.
Old 05-04-2007, 04:53 AM   #4
tone loc
tone loc's Avatar
lol i just got a jdm 7mgte-r154 combo!! taking the trans out and taking the engine apart to get a mhg and some arp!!
Old 05-04-2007, 03:17 PM   #5
supra_91
supra_91's Avatar
did you get it off of the internet. if so where? i'm looking for a 7mgte engine+tranny+ecu+wiring to do a swap
Old 05-04-2007, 03:21 PM   #6
tone loc
tone loc's Avatar
i got it off ebay from a company in canada. he said he had ten of them. payed 1500 w/o shipping
Old 05-04-2007, 03:27 PM   #7
tone loc
tone loc's Avatar
would you take out the clucth fork ??????
Old 05-04-2007, 05:41 PM   #8
Supra2NR
Supra2NR's Avatar
yes you do,
thats one of the hardest i had to do since i barely had any light to see with
and putting it back in, is not much fun either
Old 05-04-2007, 10:41 PM   #9
kwnate
SP58GT
Remove the slave cylinder.
Pull out clutch fork from drivers side inspection hole.
Unbolt the bellhousing.
Seperate motor from tranny.
Remove pressure plate, clutch then the flywheel.
Nate
Old 05-05-2007, 06:57 PM   #10
tone loc
tone loc's Avatar
i just took off the clucth cover bolts w/o taking the fork out and that worked as well
HElp with sports clutch!! whitequasimodo MKIII Supra 3 05-07-2008 11:06 PM
Clutch Troubleshooting ivire MKIII Supra 9 11-09-2006 01:29 AM
