Old 05-04-2007, 06:30 PM   #1
west_side_supra
west_side_supra's Avatar
Default wish me luck.
hi again every one for once i am not having a problem and i wanted to let you guys know that i will be doing the high school drag races at pacific raceway in kent today, so wish me luck hope i pass tech inspection. but other than that the best car i heard of being down there is a lancer evo pushin 25psi. other than that honda honda honda, and a little acura .
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 05-04-2007, 07:37 PM   #2
supramacist
supramacist's Avatar
Good Luck with that evo man.
Give them HELL.
Old 05-04-2007, 09:41 PM   #3
IHateHacks
IHateHacks's Avatar
25psi on an evo is nothing. My buddy has an 05 with 331whp running 21psi. I just saw one the other day running 51, yes that's correct, 51psi. Fuckin thing was nasty.
Old 05-04-2007, 09:42 PM   #4
supramacist
Evo's are hot off the showroom floor. I can only imagine 50psi.
Old 05-04-2007, 10:11 PM   #5
redmaro
Good luck, represent for the Mk3 community.
MK3, Auto, Turbo.
Old 05-06-2007, 03:37 AM   #6
west_side_supra
well i did pretty good, 1/4 times
1st run,shitty RT/broke my test pipe welds ran a 14.7 vs a chevelle SS i won
2nd run shitty RT again was racing a undercover cop car ran a 13.443
3rd run perfect, even did a burn out jumped at 3k rpm and did a 11.326 completely wasted the turbo desiel that got a 3 second head start
fidenza cam gears
Old 05-06-2007, 04:49 AM   #7
88Tsupra
damn nice run 11 second you put it down for us but on the second run did u win or lose
88turbo targa-white
original Pin Stripe
NGK plug and wires
HID conversion head lights
Tial BOV
BIC DDP
Old 05-06-2007, 12:29 PM   #8
IHateHacks
IHateHacks's Avatar
Holy shit 11.32!?
What do you have done to your car?
Old 05-06-2007, 05:36 PM   #9
kwnate
Scans of your slips...
Nate
Old 05-06-2007, 08:26 PM   #10
west_side_supra
id scan the slips if i had a scanner, but the 2nd one i lost because of dial in times the 3rd run i dont think i was even spose to go on the track again but i did anyways. i was also on the 2nd run hittin fuel cut like a crazy man. wwwaaaaa pop waa waa pop waaaaaaaaaaaaaaaaaaa
modifications:
ACT lightweight flywheel
aluminium driveshaft
6 puck 4 sprung clutch and stage 3 pressure plate
shimmed wastegate doing about 11-12psi
hks ssqv bov
no air filter just for that day.
3inch defcon DP
3inch test pipe
all the way back to a 3inch muffler with a silencer because the car is to loud anyways
toyo proxie 4's
adr m-sport
we also removed all the stero equipment i had a box that weighed about 50 pounds in the back then also took out the spare tire passenger seat, and back seat. and again the 1st run the welds on the test pipe broke, i get that fixed today, so i was running it right off the DP.
fidenza cam gears
1989 MKIII Build...Wish me Luck and HELP!! BoostedOne MKIII Supra 3 02-12-2009 03:02 AM
no spark chrism8799 MKII Supra 6 12-08-2008 12:38 AM
do luck middle support bar?? stiffin er up joel w MKIII Supra 1 11-09-2005 03:07 PM
Fuzzy logic boost controller... HELP. smurfmods MKIII Supra 7 10-08-2005 09:39 AM
