Old 05-09-2007, 12:40 PM   #1
jezz
jezz is on a distinguished road
Cool petrol
My 1986.5 7MGE uses a LOT of fuel... so much that now i can barely get 320km out of one tank, which i think is about 65 litres?
Anyone, please help me i'm stumped as it never leaks petrol when its parked. I'm at a point of selling the car because i can afford to run it anymore.
Also, please let me know how many kms some of you guys get from a tank.
Jez
jezz is offline   Reply With Quote
Old 05-09-2007, 02:33 PM   #2
supramacist
supramacist's Avatar
Sounds like a tune up with plugs wires and air filter and rotor and dist cap.
Old 05-09-2007, 02:38 PM   #3
IHateHacks
IHateHacks's Avatar
I have a 7M-GTE with the super monitor and my gas mileage just hit 17.0mpg, it was hovering around 16.9 until today.
You should replace the O2 sensor, and the ECT sensor along with the air filter, fuel filter, spark plugs, spark plug wires, distributor cap and rotor.
Old 05-09-2007, 02:51 PM   #4
IHateHacks
IHateHacks's Avatar
Conversion:
17 MPG (miles per gallon) = 4.5 MPL (miles per liter) = 7.24 KMPL (kilometers per liter)
I don't know the volume of the fuel tank, but if its 65L like you said then I get 470 Km to a tank.
Old 05-09-2007, 02:57 PM   #5
supramacist
You're too intelligent for your own good HH.
Take a break bro. LOL.
Old 05-09-2007, 04:20 PM   #6
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
my N/a was getting about 8 mpg then i did O2 and plugs wires, cap, rotor, and cone filter. and it raised to 15 mpg
Supra_87_mk3 is offline   Reply With Quote
Old 05-09-2007, 06:29 PM   #7
supramacist
15mpg is still not good. I'll be curious to see what I'll get with everything I have done to her. I think I did mods that were aimed to create power and efficiency.
We'll see, right. Horse Power and Efficiency don't normally go hand in hand.
Interesting none the less.
2nd thought..., 15mpg in city or town is probably not too bad. Do the o2 sensors stop working??? Or do they just get clogged to the point of dying??
How much are 02 sensors?? A left nutstickle, I bet.
Old 06-12-2007, 07:58 AM   #8
jezz
Thanks guys for your input, it ended up being the air intake tube contributing quite a bit, was leaking air badly as the tubing is cracked.
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
Can an 84' run without lead replacement added to the petrol? vixen_1505 MKII Supra 1 09-18-2008 05:56 AM
Petrol Gauge Sender Supra Mk3 supra mk3 brunei MKIII Supra 0 02-17-2008 04:14 PM
injectors squirting shots of petrol out b4 starting ....how do i fix it? mysupra MKIII Supra 0 07-01-2007 08:44 AM
