Old 05-09-2007, 05:02 PM   #1
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
Default To add to the Fuel Cut topic w/o stealing thread
i have the HKS FCD...my engine is bored .50 over,NGK plugs and wires, i only have a stock turbo and a MLS HG,ARP Studs, hallman MBC,Turbo XS BOV, and a make-shift intake (cone filter) im only going to run 10 psi until i do fuel pump and such. i was going to put the FCD on but do i even need it for this stage of upgrades. as of now stock fuel system but my next move is Walbro and 550's... also would really like to get my hands on a lexus AFM...
does anyone know what a car with this upgrade level should run?
Supra_87_mk3 is offline   Reply With Quote
supra head gasket questions+ rebuild Andy C MKIII Supra 169 05-18-2010 01:59 AM
fuel pressure boost32 Non-Generation Specific Questions 1 08-10-2008 10:19 PM
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
How much Boost on Stock Internals? abhattan MKIII Supra 26 02-20-2007 06:30 PM
