Old 05-10-2007, 04:45 PM   #1
supraman121
Default fuses in fuses block
can anyone tell what amp fuse needs to go in this spot? and how to get it out?
[img]file:///C:/DOCUME%7E1/Corey/LOCALS%7E1/Temp/moz-screenshot.jpg[/img]
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
Old 05-11-2007, 07:15 PM   #2
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
That the ALT fuse and its a 100. You have to pry out the whole piece of the fuse box them there are phillips head screws on both sides holding it in.
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
Old 05-13-2007, 03:49 PM   #3
supraman121
Are you sure? 100 what? the one i pulled out i belive was 30amps i think
K&N Air Filter
Old 05-14-2007, 01:42 PM   #4
Z'mnypit
Z'mnypit's Avatar
In your 1st pic the 100 ALT fuse is missing. In the 2nd pic the one in your hand is a 30. So which one are you wanting to know about?
Old 05-18-2007, 04:40 AM   #5
supraman121
Well the one in my hand is actually the one i pulled out of the car, well the amp that was in the car which is probly why it blow and i need to no what size to replace it with.
K&N Air Filter
Old 05-18-2007, 08:47 AM   #6
Yeah, a 30A fusible link wouldn't last very long in there. In case you're still not sure that everyone's on the same page 100A is in fact what you need.
Old 05-19-2007, 04:09 AM   #7
supraman121
lol i just want to make sure a 100a was what i needed lol acutally the 30a fuse lasted a while.
K&N Air Filter
HELP!: 7MGTE engine block info needed barton MKIII Supra 1 05-19-2010 05:54 PM
HELP!: 7MGTE engine block info needed barton MKIII Supra 6 04-14-2010 09:28 PM
prepping block for headgasket question dannydavi MKIII Supra 1 12-06-2008 07:44 AM
