can anyone tell what amp fuse needs to go in this spot? and how to get it out?
Upgrades- 225/50/R16's Kumho ECSTA AST (KU25) 273 bucks with shipping Magnaflow exhaust NO KAT K&N Air Filter www.myspace.com/coreyjstevens http://vids.myspace.com/index.cfm?fu...oid=1536317037 <------ this one should work check out the accident one aswell ya i might be a "fat kid" but i sure can move fast!~ |
That the ALT fuse and its a 100. You have to pry out the whole piece of the fuse box them there are phillips head screws on both sides holding it in.
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car" 408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's -2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's - Two 87 turbo'd/targa top'd supras (*Under Construction*) ![]() |
#3 | |
![]() Quote:
#4 | |
![]() Quote:
#5 | |
![]() Quote:
#6 |
Yeah, a 30A fusible link wouldn't last very long in there. In case you're still not sure that everyone's on the same page 100A is in fact what you need.
HELP!: 7MGTE engine block info needed | barton | MKIII Supra | 1 | 05-19-2010 05:54 PM |
HELP!: 7MGTE engine block info needed | barton | MKIII Supra | 6 | 04-14-2010 09:28 PM |
prepping block for headgasket question | dannydavi | MKIII Supra | 1 | 12-06-2008 07:44 AM |
