#6 |
after you fix the problem, you have to reset the ecu to clear codes. to do this pull the 15amp efi fuse in the engine compartment for like 30seconds. if that doesnt clear it than you still have a problem
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
Picture Of Knock Sensor Locations | ravenmaster | MKIII Supra | 10 | 01-31-2012 03:37 PM |
Starting isssues and spark knock Q's | spudz29212MKIII | MKIII Supra | 65 | 05-30-2008 06:44 PM |
Engine knock @ 1700-2300 | rstutler | MKIII Supra | 8 | 03-07-2008 07:36 PM |
Rod Knock | kewlcoconut | MKIII Supra | 20 | 01-13-2006 08:39 PM |
Knock sensor..........ebay. | rnoswal | MKIII Supra | 0 | 11-06-2005 07:24 PM |
