#11 |
haha my Powersteering pump did as well about 2 or 3 weeks later...so i took off the belt and became old fashion for a couple weeks turns out it was the Rack and Pinion
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back |
Thread Tools | |
Display Modes | |
Flowrate of the Stock Water Pump? | Bolarbag | MKIV Supra | 5 | 06-03-2008 09:26 PM |
Bad Water Pump? | scruffboy | Non-Generation Specific Questions | 10 | 11-26-2006 04:37 PM |
quick question about water pump | supfoo514 | MKIII Supra | 2 | 07-22-2006 06:17 PM |
Replace Water Pump? | Benesesso | MKIII Supra | 3 | 03-31-2006 12:26 AM |
1gte water pump | streetbeast | MKIII Supra | 15 | 06-24-2005 08:02 PM |
