Old 05-15-2007, 01:23 AM   #1
demon2supra
demon2supra is on a distinguished road
Angry newbe probs
hey yall I just got my first supra whith the 7mgte and i have codes 24 31 42 and 52 and iknow that 52 is knock sensor and 42 is vehicle sped sensor and 24 is the intake air temp sensor but the hanyes book does not give location for shit and i need help finding locations
demon2supra is offline   Reply With Quote
Old 05-15-2007, 05:05 AM   #2
redmaro
http://www.toyota-supra.info/forums/...ead.php?t=6577
^^^^^Link to knock sensor locations.
Code 31 is your Air Flow Meter(AFM).The Intake air temp sensor is intagrated into the MAF, located after your air filter, it has wiring going to it.
Your Mass air flow sensor is the screwed onto the metal housing you see in the pic. VVV
You will have to replace the air intake temp sensor and MAF as a whole, since their both integrated as one sensor.
{The MAF is not viewed in this pic.
Since you just got the car, I would reset the ecu to clear the codes and then run the car a while, and then do a diagnostic again and see what codes you get. The codes your getting may be old codes.
MK3, Auto, Turbo.
reverse probs? 89_supra_ MKIII Supra 1 12-14-2006 08:37 PM
Climate Control Probs. - Help! RyanN MKIV Supra 2 12-11-2006 10:16 PM
mkIII probs, starts then dies and then not at all katillidie MKIII Supra 3 03-30-2006 08:24 AM
rust probs. miisterMK3 MKIII Supra 2 10-11-2005 12:57 PM
87 Supra with probs beagler15 MKIII Supra 5 09-28-2005 12:06 PM
