Old 10-02-2006, 09:26 PM   #1
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Default TEMS conversion?
Is it possible to convert a NON-TEMS equipped MKIII Supra N/A (1987) to a TEMS Equipped Supra? If so how would it be done? I have looked for instruction on how to do something like that as I heard the TEMS system is absolutly awesome. I can't see it being that difficult, just a bit expensive.
Also what is the benefit of the LS400 AFM. Do I have to get new injectors? if new injectors are needed what cc should I get?
*edit* Also does anyone know where I can find a stock wing (like the ones on the turbo models)?
Thanks guys!
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
TEMS Problem! 88 MARK3 Non-Generation Specific Questions 13 11-08-2018 10:41 PM
Starting problem - Gas conversion ??? eggybread MKIII Supra 9 12-11-2008 01:48 PM
Conversion or no conversion?? 91 Supra MKIII Supra 1 06-17-2006 03:39 PM
non tems 1988gte MKIII Supra 9 04-19-2006 09:38 AM
