Old 05-16-2007, 02:35 AM   #1
demon2supra
demon2supra is on a distinguished road
Question losted power
i found that my knock senors are bad and are being replaced in about 12 hours,with them being bad will that rob low end torque and horse power?
and also i have a faint low idle miss any ideas what that could be, and does anyone have a factory service manual in a pdf format?
demon2supra is offline   Reply With Quote
Old 05-16-2007, 06:28 AM   #2
mrnickleye
mrnickleye's Avatar
Wink
http://www.swaqvalley.com/tsrm.php
http://www.turboninjas.com/mk3supra/
Download these (or one) onto your hard drive. Before they disappear off the web.
Old 05-16-2007, 04:02 PM   #3
supramacist
supramacist's Avatar
Thanks mrnickleye. I put both of those into my favorites.
Old 05-16-2007, 04:08 PM   #4
Z'mnypit
Z'mnypit's Avatar
Z'mnypit is on a distinguished road
You sure the sensors are bad? I just had a similar problem with ses "52" and I did the knock sensor rewire and all is perfect now.
What code is your car throwing?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car"
408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's
-2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's
- Two 87 turbo'd/targa top'd supras (*Under Construction*)
Z'mnypit is offline   Reply With Quote
Old 05-16-2007, 07:31 PM   #5
marc
how did u go about doing the rewire..i was thinkin of doing it but it looked liek a pain so i was ganan send it to a shop, dont u have to cut into the wiring harness?
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 05-17-2007, 07:28 AM   #6
demon2supra
Question
well i had a code 51 then 52 and the rear knock sensor was actually broke off
now im still getting the low idle miss and now it is missing under boost and throwing no codes have any clue and well i stumped.?
Old 05-17-2007, 12:26 PM   #7
Z'mnypit
Z'mnypit's Avatar
Followed these directions. http://www.supras.com/06/techcenter/display.php?QID=69 Its really simple. Took me about and hour. The only thing the directions say do that I didnt do was also ground it by the strut. Theres no need to ground both ends, just on by the PCM is fine.
Old 05-18-2007, 08:55 AM   #8
demon2supra
Smile
well i found a small ground from the base of the coil pak plate that was broke since i have replaced but i still have a slight low idle miss and slight miss under boost can anyone point me in some direction?
Old 05-19-2007, 04:05 PM   #9
demon2supra
Cool
is the code 51 knock senor singal? also where can i get the thin net wire and it does have to be the 50 ohm
Old 05-19-2007, 10:11 PM   #10
j3pz
use insulated wire, like rg58. i dont believe network wire is insulated as much as rg58.
Greetings! importauto Import Auto Center 7 06-21-2009 07:42 AM
getaway in stockholm... (i think thats how you spell it) kelogg Road Racing & Autocross 3 06-03-2008 10:53 PM
Lsd RussianMK3 Drifting 6 12-10-2006 05:42 PM
Ghetto is a good seller ARZ Buyer/Seller ratings 0 11-15-2006 11:58 PM
MEET UP's TEAM_Bastos Drifting 0 03-02-2006 09:09 PM
