Old 05-16-2007, 07:19 PM   #1
Sonic
Sonic's Avatar
Sonic is on a distinguished road
Default Exhaust system
I'm looking at different systems and due to the fact that my 91 supra has a cat converter and 2 oxygen sensors you cant take it off .... so now i have to buy a engine management system.... ? is that the only way?
Sonic is offline   Reply With Quote
Old 05-16-2007, 08:56 PM   #2
Supra2NR
Supra2NR's Avatar
Its called a "bung", weld it into the exhaust pipes for the 02 sensor to bolt up
But, while were in this subject
I know the bung is not gonna work with the mk3 o2 sensor since its on a flange with two bolts
Here's my question, if I used another 2-wire o2 sensor , will it work with my car?
Cuz idk where I can find a flange for mine
So I'm gonna try to use a 2-wire o2 sensor with the thread, so I can use a bung to weld on my downpipe
Old 05-17-2007, 02:01 AM   #3
IHateHacks
IHateHacks's Avatar
Bung, thats a funny word.
I need TP for my BUNG HOLE!!
Old 05-17-2007, 10:14 AM   #4
Sonic
Sonic's Avatar
I guess there's not many choices .... guess well have to smoke da Bung!!
Old 05-17-2007, 04:47 PM   #5
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
are we still on that Puff Puff pass rule?
Supra_87_mk3 is offline   Reply With Quote
Exhaust System SideWinderGX MKIII Supra 8 02-28-2007 08:01 AM
i was thinkin side exit exhaust system for my 87 supra.... the t3d MKIII Supra 11 10-05-2006 05:02 PM
BLITZ Nur Spec Racing Series Cat-Back Exhaust System??? HeadofaHessian MKIII Supra 0 11-10-2005 05:24 AM
exhaust system kewlcoconut MKIII Supra 10 11-02-2005 07:46 PM
