Old 05-16-2007, 11:21 PM   #1
waytofast4u
waytofast4u is on a distinguished road
Default mhg size
My machine shop guy told me the block was shaved off 7thousandths and the head was shaved off 12thousnadths..What size MHG should i get could any1 help me thanks guys! the block was bored to 83.5mm
waytofast4u is offline   Reply With Quote
Old 05-17-2007, 01:06 AM   #2
supramacist
supramacist's Avatar
www.horsepowerfreaks.com
extention 103.
speak to Dave
He can and will help you.
Old 05-17-2007, 04:45 PM   #3
Supra_87_mk3
Supra_87_mk3's Avatar
Supra_87_mk3 is on a distinguished road
i second that he is a real help always has a way to figure it out..
1-866-473-5600 ext.103 dave
now you dont even hafto find the #.
if he doesn't ansure call back its worth it.
My 1989 toyota supra mods:83.5 mm bore, ARP main studs, ARP rod bolts,rings, Cometic .060" headgasket, ARP head Studs, Ferra 1 mm oversized valves, port work, Rc 550cc injectors, Walbro 255hp
Turbo: 1.15 A/R T4 twin Scroll turbin - journal .60 A/R compressor, Hallman Pro MBC, Turbo XS Blow-off Valve, 50mm wastegate, hks fcd
Intercooler: 32x12x3 core, 3 inch piping, with clampco t-bolt clamps
Exhaust:Exhaust manifold T4 twin scroll,2JZ 3 inch downpipe Fabed up to fit, Mandrell bent 3in back
Supra_87_mk3 is offline   Reply With Quote
Old 05-17-2007, 06:43 PM   #4
supramacist
I'm guessing you'll need a 2.mm. But I always guess that, lol.
Optimal Size JPDsupra MKIV Supra 1 06-30-2007 12:39 PM
bolt size? west_side_supra MKIII Supra 5 04-08-2007 06:18 PM
Whats the best catylac converter size 88Tsupra MKIII Supra 6 02-09-2007 07:58 AM
