Old 05-16-2007, 11:57 PM   #1
D_Train
D_Train is on a distinguished road
Default What is a good way to clean out the engine bay?
Whats the best way to clean out the engine? Just a rag and some scrubbing strength? are there products that can clean the grease off of everything no problem?
Also, i'm not talking about just the engine bay, but also the other components in the engine.
D_Train is offline   Reply With Quote
Old 05-17-2007, 01:11 AM   #2
supramacist
supramacist's Avatar
pb blaster. at auto stores and wal-mart.
Old 05-17-2007, 01:47 AM   #3
IHateHacks
IHateHacks's Avatar
Brake cleaner works better than PB. It also dries alot faster than PB. PB actually leaves a residue that will burn off if the part that you sprayed with it gets hot.
Most grease will just disappear if you hit it with brake cleaner.
PB is used as a penetrant and rust inhibitor, its not known for its cleaning ability, although it does work but smells like ass and doesn't evaporate in seconds like brake cleaner.
Old 05-17-2007, 01:53 AM   #4
supramacist
I think the ass smell helps it work better, and it doesn't wash out of clothes.
Old 05-17-2007, 02:36 AM   #5
D_Train
What can i get the brake cleaner on as far as engine parts? Like, if I just go wild and spray it on everything and start wiping will i hurt anything? obviously i'll use some discrection (sp?) but you know...
Old 05-17-2007, 02:55 AM   #6
redmaro
I wouldnt spray it on the electronic parts, for pretty obvious reasons.
MK3, Auto, Turbo.
Old 05-17-2007, 03:55 AM   #7
Kuban
Kuban is on a distinguished road
break clean works amazingly, i used about 7-8 cans on my engine swap and everything looks brand new, from the turbo, turbo manifold to valve covers. Do yourself a favor and buy a cheap brand, otherwise it gets pricey for parts cleaner. Its all basically isopropyl anyway.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Kuban is offline   Reply With Quote
Old 05-17-2007, 04:04 AM   #8
mrnickleye
mrnickleye's Avatar
Wink
There are different brake sprays out there, so check the chemical ingredients on the cans.
Years ago it was 111. trico, which was great, and could be used on everything without harm.
But now some have acetone, which you DON'T want to get all over and into electrical connectors. The puddling liquid will damage the plistic.
Johnsen's brake cleaner spray's main ingredient is acetone.
If there is a bunch of grimmy grease stuff, then use some spray engine degreaser (99cent store), or pure Simple Green. Let it sit on the area for about 30 min, then wash that off with brake spray.
DON'T do it in the driveway, as you will have a mess.
NEVER, NEVER, NEVER use carberator spray. Do you have a carberator on your car? NO!
It way to strong, and WILL damage plastic.
Also, be sure to protect your fenders, and paint.
Old 05-17-2007, 05:03 AM   #9
Bman86.5
Bman86.5 is on a distinguished road
with the brake cleaner (tetrachlorethene) it will take a layer of paint or more so make sure you have degreaser and some water to wash it off, so u don't take more paint off than u want. other than that make sure ur clean and careful not to get it on the outerpaint or it could cause paint and clearcoat damage
Bman86.5 is offline   Reply With Quote
Old 05-17-2007, 05:28 AM   #10
Kuban
yea i got a little on my block when i did my eninge swap and it litterally started to strip the high temp paint off the block lol.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Good engine builder in PacNW? tsupranami MKIII Supra 5 03-17-2009 04:37 AM
good engine west_side_supra MKIII Supra 4 01-23-2008 06:10 AM
Is the 1JZGTE a good engine? Legionnaire MKIII Supra 7 03-16-2006 07:26 PM
