Old 05-18-2007, 09:51 AM   #11
Kuban
Kuban is on a distinguished road
Originally Posted by dcrusupra
Ok well i should have said it would be better (instead of need) to put it in a cooler spot in the engine bay. Simple science tells you that if the surrounding air is colder it'll allow more vapors to into the catch can as opposed to it being next to the turbo. You can mount the catch can pretty much anywhere if need be. Just because some companies make brackets for a certain spot doesn't mean that is the recommended place for it.
Im not against putting it somewhere else, the only reason i wanna put it where the evap can is, is because iv never seen it anywhere else before. Iv tired to place it in many areas of the engine bay. But it doesnt make sense to put it on the driver side since both routings run to the passenger side, and if you really take this catch can and try to mount it somewhere inside of the passenger side, the only places it really fits with a decent amount of space, is either on the stut tower (RIGHT next to the turbo) or where the evap can is (behind and to the side of the turbo), so i choose the best spot of my descression. If you have other ideas by all means, please recommend them, thats why this topic is here.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Kuban is offline   Reply With Quote
Charcoal Canister, is it OK? Busted Knuckles MKIII Supra 1 11-10-2008 08:47 AM
Charcoal canister clogged elliotl MKIII Supra 0 08-27-2007 04:21 AM
charcoal canister zuni MKIII Supra 4 06-17-2007 02:03 AM
Charcoal Canister Opens? scruffboy Non-Generation Specific Questions 0 10-10-2006 12:17 PM
