#1 |
i found that my knock senors are bad and are being replaced in about 12 hours,with them being bad will that rob low end torque and horse power?
and also i have a faint low idle miss any ideas what that could be, and does anyone have a factory service manual in a pdf format? |
#2 |
http://www.swaqvalley.com/tsrm.php
http://www.turboninjas.com/mk3supra/ Download these (or one) onto your hard drive. Before they disappear off the web.
Had a Red 1989 N/A. Automatic. Sports Pkg. w/wing. TEMS, and some nice MODS. Sold to a friend 10/08/08. |
#3 |
Thanks mrnickleye. I put both of those into my favorites.
#4 | |
![]() Quote:
What code is your car throwing?
-99 Z28 A4 6.7L "2006 LS1tech Calendar cover car" 408ci, Comp 244/248, Patriot Stage III LS6 heads, FAST 90mm Intake, NW 90mm TB, SVO 42lb'rs, Pacesetter LT's, ORY, 4L80e, Yank 3400, Motive 3.73's, Racetronix, TNT 200shot, Fikse FM10's -2005 Silverado Crew Cab 5.3L (Towing), Silverbirch, Hooker Aero Chamber, blacked out windows, sittin on 22's - Two 87 turbo'd/targa top'd supras (*Under Construction*) ![]() |
#5 |
how did u go about doing the rewire..i was thinkin of doing it but it looked liek a pain so i was ganan send it to a shop, dont u have to cut into the wiring harness?
![]() nothing but the best -mods- so far K&N intake fipk 3" megan downpipe 3"turbo elbow 4 washers on the wastegate highflow cat short shifter 89+ front bumper, pic soon to come many more upgrades soon |
#6 | |
well i had a code 51 then 52 and the rear knock sensor was actually broke off
now im still getting the low idle miss and now it is missing under boost and throwing no codes have any clue and well i stumped.? Quote:
#7 | |
![]() Quote:
#8 | |
well i found a small ground from the base of the coil pak plate that was broke since i have replaced but i still have a slight low idle miss and slight miss under boost can anyone point me in some direction?
#9 | |
is the code 51 knock senor singal? also where can i get the thin net wire and it does have to be the 50 ohm
#10 |
use insulated wire, like rg58. i dont believe network wire is insulated as much as rg58.
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
Greetings! | importauto | Import Auto Center | 7 | 06-21-2009 07:42 AM |
getaway in stockholm... (i think thats how you spell it) | kelogg | Road Racing & Autocross | 3 | 06-03-2008 10:53 PM |
Lsd | RussianMK3 | Drifting | 6 | 12-10-2006 05:42 PM |
Ghetto is a good seller | ARZ | Buyer/Seller ratings | 0 | 11-15-2006 11:58 PM |
MEET UP's | TEAM_Bastos | Drifting | 0 | 03-02-2006 09:09 PM |
