Old 05-19-2007, 07:02 PM   #1
west_side_supra
west_side_supra's Avatar
Default what the hell
my car cant seem to work perfect for more than a month i swear.
ok so these past 2 days my car has been being a little biatch when it comes to starting it cold. i mean leave it over night and come back the next morning to start it. it will sit there and turn over and keep turning over. then i stop and try again it will sit and turn over and over with maby a little hicup here and there. i can smell what smells like exhaust coming out of the exhaust pipe. so im guessing its getting fuel.
once i get it running i can start it up again no problem. im guessing maby something to do with the cold start system, ill run a diagnostics to see if anything pulls up.
oh and me and a friend put on some hard pipes for the upper ic pipeing. i dont think its leaking at all anymore but ill spray some like carb cleaner in around the pipes to see if the RPMs raise up at all.
thanks again guys
7MGTE - 500hp never dyno'd
fidenza cam gears
Alarm Hell!! alarm_07 Car Audio and Alarms 21 06-23-2010 02:40 AM
What The Hell Does This Mean? dexst MKIV Supra 3 04-08-2008 10:00 PM
hotter than hell tone loc MKIII Supra 11 08-24-2006 08:39 PM
hell reep Non-Generation Specific Questions 0 12-01-2005 02:23 PM
what the hell is that body kit in_search_for_a_supra Non-Generation Specific Questions 6 06-23-2005 12:43 PM
