Old 05-30-2007, 05:28 PM   #1
Arne (Denmark)
Arne (Denmark) is on a distinguished road
Default 7MGE oil pressure
Hi there. My first time here.
I have a 1987 MKiii Supra (7MGE) which I bought three months ago.
I topped up the oil with some Mobil 10W40 oil even though the guy I bought it from said I should use 15W-40, because the mileage is about 250.000 km
The problem is that after that the oil pressure has tuned down quite a bit. Normally the pressure idling was 1.7 kg/cm3.
Now I can hardly get the pressure to rise to more than 2.0 and it's generally too low. -Only about 1.0 idling.
AND there is a rattling, knocking from the engine!? Nothing when it's idling but gets bad about 2000-3000 rpm. Hmmmm.
Have you guys ever had or heard an oil pump go bad?
What is your normal oil pressure reading on the cars?
Can a faulty bearing cause the oil pressure to fall?
After all I hope it is only my oil pump otherwise I got to look around for another engine.
I will be happy for your comments.
Arne (Denmark) is offline   Reply With Quote
Old 05-30-2007, 07:11 PM   #2
Bill UK
AEM EMS
Bill UK's Avatar
Sorry but that sounds like big ends to me, mine started knocking at start up from cold and then disappeared until about 2K to 2.5 K revs. Driving back from work one night the engine just seized, being an auto the supra just skidded to an immediate holt. Just avoided a ten-car pile up behind me. I drained the oil but found no evidence of bearings wear, but after opening up the oil filter I found bits of bearing shell. Striped the engine down to find the crank was beyond a regrind due to hairline cracks. My advice would be don’t drive it and don’t make any plans to buy parts until you have checked out the crank..
Old 05-30-2007, 07:14 PM   #3
Bill UK
AEM EMS
Bill UK's Avatar
Bearing Shells.
Old 05-30-2007, 09:17 PM   #4
Arne (Denmark)
Default Thanks Bill.
Damn it.
I hope that it's a rod bearing or more.
I will have to split it apart and will take photos to show others what has or is going wrong in my engine.
Bill, thanks. Did you notice that your pil pressure became lower and lower?
It's summertime and now this has to go wrong now the car being a Targa..
that's life.
Old 05-30-2007, 10:30 PM   #5
Bill UK
AEM EMS
Bill UK's Avatar
That’s how it first started; the oil pressure would normally be just below 60 psi at 3,000 revs continuous driving. The first indication of any problem was when it dropped to 40 psi at 3,000 revs. 40 psi is probably within the supras specification, but as I normally would run at 60 psi I started to get concerned. The obvious thing to do was to change the oil and oil filter; this improved the oil pressure but only for a short time.Then the slight knocking started, the rest is history. I think the first thing to do is to open up the oil filter and to see what's inside; this should give you some idea of any internal engine wear. Apparently its common practice to open up the oil filter for inspection on aircraft engines. I suppose when you think about it, it makes sense.
Old 05-30-2007, 10:37 PM   #6
Arne (Denmark)
BTW.
When the car idles it sounds like a new engine. No knocking at all. Only when you accelerate the engine makes a rattle and I suspect that one ore more valvelifters might not be opening. I've heard this before on other cars and they can make a terrible noise.
I topped up the oil with some thinner oil and now the problem arose. I will change the oil to see whether this helps and check the cylinder head/valve lifters to see for damage.
I have found that the pressure is actually "ok" for the oil. It is supposed to be 0.3kg/cm2 or more once idling. 2.5-5 kg/cm2 at about 3000rpm.
Am I right. If it was one or more bearings the car would knock once idling as well?
All just assumptions but you guys must know how nervous a person gets once your baby is sick :-)
I hope for the best. The engine is otherwise so smooth and cultivated...
Old 05-30-2007, 10:47 PM   #7
Bill UK
AEM EMS
Bill UK's Avatar
Arne I've just had an idea, your 1 hour ahead of me and I'm 5 to 7 hours ahead of the US. If you shipped your supra to the US you could go back in time when it was ok.. Must remember to stop watching those time travel movies!
Old 05-30-2007, 10:54 PM   #8
Bill UK
AEM EMS
Bill UK's Avatar
Mine started knocking at start up from cold and then disappeared until about 2,000 revs to 2,500 revs. At any other revs you couldn't hear it. Once the engine had warmed up it sounded normal at tick over.
Old 05-30-2007, 11:18 PM   #9
Arne (Denmark)
haha ok Bill once the bill from Toyota comes I might wish I never bought the car.
Well, mine sounds like a new car on start up. Only when you drive it at normal town cruising up to 2-3000 rpm you can hear the tapping when one changes gears " a sort of tapping".
Actually a bit like this one!
http://www.youtube.com/watch?v=B0Zq6-YaKDU
It sounds just like mine. Only this car has a slight rattle once idling - my car hasn't. It sounds fine!
I hope it can be a valve lifter problem. Uhhh, I hope not to find metal in my oil filter. :-( I am not going to drive the Supra before the things are sorted out.
But Bill it actually sounds like we don't have the same symptoms after all. At least I hope my problems aren't that big. What did you do to your car? Did you fix it yourself?
Bill, I appreciate your replies! thanks! :-)
Old 05-31-2007, 04:06 AM   #10
btwilson86
Super Moderator
btwilson86's Avatar
I don't know if this helps or not, but I used to own a 95 Saturn SC1. I put Mobil 1 oil in it at one of the oil changes, and shortly later it developed a similair condition. The only difference between the video's sound clip and mine is that my knocking went away at about 2000 rpms. I didn't own the car long enough to take it apart and fix (plus it was a POS anyway) cause it got impounded. I had talked to a mechanic briefly about it and he said that the Mobil 1 oil tends to seperate itself when put into engines that haven't used it since the beginning. He didn't tell me why this happens though...
Anyway, I don't really have any advice on how to resolve it, but all I know is it doesn't sound like rod knock (or at least what I've heard from before my Supra's engine blew).
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
How far can you push a 7MGE on turbo? Turbotuner2.3 MKIII Supra 6 10-26-2007 09:12 PM
oil pressure guage in nonturbo 7mge nosd112 Non-Generation Specific Questions 1 07-05-2006 08:09 PM
7mge vs. 7mgte KNYFE MKIII Supra 3 09-27-2005 02:21 PM
