so i was just wondering if you where to cut the spings by maby a coil, would the tems unit go all wacky on you like keep going from sport to super sport or whatever the 3rd stage is all the time. or would just keep working like normal?
![]() 7MGTE - 500hp ![]() exhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
No it won't mess up the tems, but cutting your springs is a horrible idea. Lowering springs only cost $200....
Nate ![]() ![]() |
I would also get some lowering springs because I know some one who cut their springs on their car about 2 inches and the car was very very hard and super bouncy. if you get some lowering springs then you wont have that problem.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior. |
god if you wanna be cheap get a civic
88 N/A w/ 5spd - stock - not running, bhg 87 turbo/targa w/ 5spd- fidanza light weight flywheel, new oem slave cylinder, apexi air filter, no ac and no heat |
#5 | |
Screw that TEMS, that shits junk. It's 20 years old. I'd get a set of coilovers, thats what I'm planning to buy next.
#6 |
i wasnt talking like 2 coils just 1, thats maby an 1inch if that. so just a little lower, and i dont have 200$ right now
