#1 |
i just picked up a air fuel ratio gauge and i was trying to figure out what color wire i need to use for oxigen sensor, the ECU one im guessing.
either i did find the right one and its telling the truth and the car is running beyond rich or its just a wrong wire ![]()
![]() 7MGTE - 500hp ![]() exhaust: 3inch pipes no cat/powerhouse manifold/garret gt47 18psi/HKS SS racing wastegate fidenza cam gears intake: PHR 4inch intake/K&N filter/3 inch intercooler/ pipeFMIC/greddy type R bov/ fuel: 550cc PTE/ walbro 255lp / Aeromotive adj pressure regulator transmission: Fidenza flywheel/ACT extreme kit electronics: map ecu 1 / HKS EVC 9 gauges:boost,EGT,oil temp & pressure/aem AFR |
Fuel pump relay and pressure. | carfanatic89 | MKIII Supra | 8 | 05-01-2008 06:39 PM |
Fuel issues!! | teedoff00 | MKIII Supra | 1 | 01-01-2008 05:09 AM |
Testing for bad ECU, &/or bad Fuel Pump | elliotl | MKIII Supra | 0 | 08-21-2007 10:42 PM |
air fuel gauge | Supraman | MKIII Supra | 6 | 07-20-2006 06:20 PM |
