Old 06-08-2007, 11:13 PM   #1
west_side_supra
west_side_supra's Avatar
Default Air fuel gauge
i just picked up a air fuel ratio gauge and i was trying to figure out what color wire i need to use for oxigen sensor, the ECU one im guessing.
either i did find the right one and its telling the truth and the car is running beyond rich or its just a wrong wire
7MGTE - 500hp never dyno'd
fidenza cam gears
Old 06-08-2007, 11:27 PM   #2
Supra2NR
Supra2NR's Avatar
those ones are not really that reliable or accurate for that matter
i wouldnt trust that gauge 4 sh!t
Old 06-09-2007, 12:17 AM   #3
west_side_supra
i already know that its not that accurate, but the fact is the car is running rich. i already knew this, but i just got it so that when i buy or fix things its good to know if im acually doing anything to get it closer to running right.
fidenza cam gears
Old 06-09-2007, 04:16 AM   #4
It's not just a matter of how much info they display, but the consistency of it. Try connecting a volt meter to the O2 line and you'll see the signal bounces all over the place. Unless the gauge is heavily buffered (in which case it's worthless for a different reason) it's still not going to really provide you with any decent information... not even a good basis for a hunch.
As for which wire, what year and model are your car?
Old 06-09-2007, 05:51 AM   #5
west_side_supra
87 turbo, its got the heated wires for the 02.
fidenza cam gears
Old 06-09-2007, 06:39 AM   #6
'87-'88 Turbo ECU pinout is here: http://www.fadingworld.com/Supra/MAF...0-%2087-88.jpg
Don't refer to the diagram for anything else though, it's incomplete.
Fuel pump relay and pressure. carfanatic89 MKIII Supra 8 05-01-2008 06:39 PM
Fuel issues!! teedoff00 MKIII Supra 1 01-01-2008 05:09 AM
Testing for bad ECU, &/or bad Fuel Pump elliotl MKIII Supra 0 08-21-2007 10:42 PM
air fuel gauge Supraman MKIII Supra 6 07-20-2006 06:20 PM
