Old 06-09-2007, 06:03 AM   #1
marc
Default hmmm well maybe its the tps
ok well my car hits 2k rpm and hits fuel cut, until i shift, and can rev up to 2k again lol so im thinking its the tps..so i got a new one and im ganna reset it tommorow i mean igot a code 41 and the last sensor, no matter hwere i put it, the numbers on the ohm meter just culdnt match up to what they shuld be, i baught a new sensor and am waiting to postition it tommorw, i hope this works
nothing but the best
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
4 washers on the wastegate
highflow cat
short shifter
many more upgrades soon
Old 06-09-2007, 02:20 PM   #2
marc
well im pretty sure i set the damn tps right but its stillnot working correctly, now i hit fuel cut, just 200rmps later...its fuckin shitty im ready to sell the supra
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 06-09-2007, 02:22 PM   #3
Japanese supra tt
Japanese supra tt's Avatar
Japanese supra tt is on a distinguished road
dont sell the sup!
if its turbo, check for boost leaks, you could be getting a boost leak and that would cause less air in the engine so it would pretty much bog the motor down with fuel and die.
i dunno, just my 2 cent thoughts
Japanese supra tt is offline   Reply With Quote
Old 06-09-2007, 02:37 PM   #4
marc
idk anywhere there cul;d possibly be a boost leak tho...when i finished replacing the headgasket it was running liek this, and i was getting a code 41 which is throttle position sensor signal
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 06-09-2007, 02:41 PM   #5
Japanese supra tt
Id check all the hoses and anything rubber that could be torn or cracked just in case.
but since your gettin a code 41, its gotta be the TPS, but you never know, those pesky hoses.
i dunno man, thats all i got.
good luck with your problem though mate
Old 06-09-2007, 02:42 PM   #6
marc
and its not a bogged down feeling, once my car hits around 2k rpm it just dies, until i shift or until the revs drop. and then gets power right away again, and idk if its a boost leak because the car will start to boost...but then due to the fuel cut i cant rlly see it boost n e more
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 06-09-2007, 02:43 PM   #7
Japanese supra tt
oh dam well its gotta be something to do with the TPS.
hmmm
Old 06-09-2007, 02:53 PM   #8
marc
idk im ganna try to adjust it again or sumthing, im ready to call it wuits and take it to a shop
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 06-10-2007, 09:56 PM   #9
marc
idk any more i replaced the tps and thought i had reset it right, but i baught i used one with a new throttle body but its still doing the same thing...im ganna buy a new tps and see if thats it..and if its not..im giving up and either takin it to a shop or selling it
-mods- so far
K&N intake fipk
3" megan downpipe
3"turbo elbow
highflow cat
short shifter
Old 06-11-2007, 12:26 PM   #10
you're hitting fuel cut very early, does it blow alot of black smoke out the exhaust? how does it idle?
Engine Problem Stymee14 MKII Supra 2 08-06-2007 02:17 PM
83 ECU on a 82 Cowardsrus MKII Supra 3 05-29-2007 06:46 PM
Auto to Manual transmission? dannydavi MKIII Supra 19 05-18-2007 05:33 AM
89 supra. lots of problems.. HELP!! 89_supra_ MKIII Supra 9 12-15-2006 02:28 AM
painting my grill? newbsupra MKIII Supra 18 09-03-2006 12:55 AM
