Old 06-14-2007, 08:30 PM   #11
IHateHacks
IHateHacks's Avatar
My 7M with 120K miles and a blown head gasket had 180psi on every cylinder. You say only one was low but thats 1 too many if you catch my drift.
I'm thinking more manufacturer defect than a bad injector.
Let us know what happens.
Old 06-15-2007, 05:03 PM   #12
Kuban
Kuban is on a distinguished road
Well thing is, i called jasper. The warrenty guy that talked to me said its not a defect. Hes saying its my fault. I dont see how but ok. Not many things cause a cylender to lose compression like that just short of rings breaking in two. I dont know what to do now. They wont warrenty it.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
Kuban is offline   Reply With Quote
Old 06-15-2007, 06:24 PM   #13
Kuban
Well i think im just going to do a rebuild and do it right myself. I priced myself around 3k for starters.
1100 rods, Brian Crower (1500hp rated)
715 pistons, Ross Pistons
125 head studs, ARP
180 head gasket, COMETIC
265 engine gaskets, Toyota
65 main bearings, Clevite
30 rod bearings, Clevite
73 rod bolts, ARP
total w/o machine work : $2,553
Pricey but could be a promising set up after future fuel and turbo upgrades later.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-15-2007, 06:26 PM   #14
supramacist
supramacist's Avatar
It's no worse than re-building a stock engine. But I would stay on them.
Obviously something they did is wrong. I'm sorry to hear that, I for 1 will no longer direct anyone in their direction as for engine alternatives.
Old 06-15-2007, 07:32 PM   #15
Kuban
There telling me im getting detonation and its probably blowing the inner head gasket. Thats why i have compression loss. Although i dont have any coolant issues.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-16-2007, 06:54 PM   #16
Kuban
well i guess im hoping it could be the headgasket in that cylender. That would explain it, although i havent been having coolant issues and my oil looks normal. Yesterday the temp rose up to the top and dropped right away. I dont know what that means.
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-17-2007, 12:35 AM   #17
supramacist
My temp used to do that right before the hg blew the fiznuck out, and I mean lost its' wad. Broke the rear off of 6 on a graphite hg bloched job by previous owner.
Old 06-17-2007, 12:44 PM   #18
IHateHacks
IHateHacks's Avatar
See, I'm not the only one who thinks you didn't have enough fuel.
Run a block test to see if your HG is blown.
I would add ARP main studs to that list if I were you.
Old 06-17-2007, 05:30 PM   #19
Kuban
well if it happens to be the hg i dont plan on doing a rebuild. Ill simply get a mls head gasket with some arp bolts or studs. Since theres only 3k miles on this engine and its a mild blow, the head should still look brand new. Although ill send it out to get resurfaced. The block however should be ok. Well see when i pull the head. As to the fuel thing. I dont think it is fuel at all. I tuned this car specifically to run really rich. Reason being when i did end up turning up the boost. My fuel is there to compensate. I never retorqed the hg and i was running 12-14 psi out of a .57 trim ct-26, thats why my hg blew. I just hope it last till the cash is there to do this tear down.
Btw i hate hacks, where can u get one of those block resurfacing tools you were speaking of? The big ass heavy thing you turn on top of the block?
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-eibach springs
-slotted rotors
-targa
-greddy turbo timer
-egr eliminated
-n/a cams
Old 06-18-2007, 01:12 AM   #20
IHateHacks
IHateHacks's Avatar
I borrowed it from one of my boys from this site.
They cost like $400 but I don't know where he got it.
1990 supra turbo engine issues help jespat Non-Generation Specific Questions 4 01-24-2008 02:37 AM
90' engine in 87' w/ tranny issues. chash360 MKIII Supra 2 12-11-2006 05:39 PM
