#21 |
see if you can maybe get in touch with him, id like to talk to him.
-868 Miles on new jasper engine -All hard pipes -0.57 trim ct-26 -greddy type S -greddy profec b -apexi ride high 7 way adjustables -eibach springs -slotted rotors -mkIV TT rims (front)245/45/17 (rear)285/40/17 -targa ![]() -greddy turbo timer -egr eliminated -3" turbo back, no cat, no resonator, Apexi N1 back. -n/a cams Theres others ill think of later. |
#22 |
Well you see, he lives in my state, only about 30 minutes away. He brought it over and left it here for a couple months, then came and picked it back up.
#23 |
how heavy is it again? like 50lbs u said?
#24 |
If not more. That thing is HEAVY.
Even if you borrowed one, you still need to source some lapping compound. If I was faced with your situation, I would pull the block, strip it and send it to a quality machine shop and have them deck it. Then build the snot out of it, just like you listed all those parts. Yes, I know its easier said than done, and I know the cost involved, but thats what I will be doing if my 7M ever takes a dump. |
#25 |
Sorry I scrolled back.
#26 | |
Right but keep in mind. This is a head gasket blow on 3k mile engine. On top of that they dont use a toyota head gasket, they used some other company for the gasket kit. It says nascar on it i dont know. But i dont think the hg they use has the gouges in it that toyota's gasket does. So to be honest the block surface shouldnt be that scored. I really dont think sending it out is necessary. Ill have to look when i pull it. im not gonna rebuild this thing if theres no internal damage, because those parts are still under warrenty and i kinda wanna keep that warrenty just for a warm fuzzy feeling inside.
#27 |
You won't know until you pull it.
You could be right. Depends though, on a few things. But you know this. Go for it. |
Thread Tools | |
Display Modes | |
problem seperating engine from manual tranny | Gengus | MKIII Supra | 7 | 01-29-2008 12:10 AM |
1990 supra turbo engine issues help | jespat | Non-Generation Specific Questions | 4 | 01-24-2008 02:37 AM |
90' engine in 87' w/ tranny issues. | chash360 | MKIII Supra | 2 | 12-11-2006 05:39 PM |
