Old 06-11-2007, 05:05 PM   #1
igosaur
igosaur's Avatar
igosaur is on a distinguished road
Default Rear brake pads
I`m just about to attempt to change the rear brake pads on my 1989 3.0i Supra but never having done this sort of thing before I turned to the Haynes manual.
This being next to useless I looked up changing pads on the internet.
This is what I found..
http://www.cockeyed.com/lessons/brak...eshoes01.shtml
My question is basically this. Would the instructions given in this article transfer well to me changing the rear brake pads on my Supra? i.e. Are they all basically the same?
Any help would be greatly appreciated
igosaur is offline   Reply With Quote
Old 06-11-2007, 05:28 PM   #2
Drag0na5h
Drag0na5h's Avatar
Drag0na5h is on a distinguished road
Yes that's a very good guide to follow. Just take your time when taking anything off to note what it looks like while it's on so you are confident after the job is finished that it was done right. When doing the supra brakes two metal V-shaped springs are attached to the brake pads via a few holes. Note how they are before taking them off and putting them in the new pads.
Drag0na5h is offline   Reply With Quote
Old 06-11-2007, 05:43 PM   #3
igosaur
igosaur's Avatar
Thanks for that Quite a relief I can tell you.
Just one last question. Should I leave the hand/parking brake on or off?
Thanks again..
Old 06-11-2007, 06:34 PM   #4
supradaddy0803
supradaddy0803's Avatar
If you are jacking up the whole back end and puting it in jack stands then it doesnt really matter seeing as the e brake pads are inside the rear brake rotor. If you are just jacking one side either put the e brake on or chock the front wheels it will roll and you could be under it better safe then sorry.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-12-2007, 03:10 PM   #5
Drag0na5h
Drag0na5h's Avatar
Always put a chock on both sides of one front wheel that is going to stay on the ground when you lift your car up. I'd recommend doing one side at a time since your front wheels don't have any other way of keeping still without a chock. If lifting the front end I feel okay doing both since I got both e-brake and chocks for safety in the rear.
need help replacing 89 supra front and rear brake pads 89supra323 MKIII Supra 16 05-25-2007 12:43 AM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
