Old 06-14-2007, 04:37 AM   #1
D_Train
D_Train is on a distinguished road
Default Foglight question
I have a 1986.5 supra and every time i go to the auto parts store they try to sell me the bulb for the fog light but i'm 90% sure that i need the entire unit not just the bulb. Can anyone tell me what I need?
D_Train is offline   Reply With Quote
Old 06-14-2007, 04:48 AM   #2
btwilson86
Super Moderator
btwilson86's Avatar
If you have the foglight itself, then don't replace it. You can buy the bulbs seperately. I think they are H3 bulbs.... Don't quote me on that though. I removed the entire foglight housing to determine why mine weren't working, and after I took them apart I found out that the bulb in each one was bad. Disconnected it, went to AutoZone, got two new ones, put it back together and on my car, and *Voila* no problems.
Old 06-14-2007, 07:13 AM   #3
Somajunkie
Somajunkie is on a distinguished road
The bulbs should be H3 with 55watts, I just changed a fog light that went bad last week so yeah. Its really easy to do, just unscrew the fog light unit, take the old bulb out and replace it with the new one.
Somajunkie is offline   Reply With Quote
Old 06-17-2007, 05:32 AM   #4
88Tsupra
88Tsupra is on a distinguished road
dont mean to jack the thread. but my fog light went out too after i put in my HID head lights and i bought new bulbs change fuse and i still cant get the foglights to work n e one know why
88turbo targa-white
original Pin Stripe
custom intake-Tenzo filter.....Momo racing seats and steering wheel...
apexi exhaust tip-custom 3" piping. Replaced with RSR GT II
NGK plug and wires
HID conversion head lights
HKS Turbo Timer Type-1 (in black)
Tial BOV
BIC DDP
88Tsupra is offline   Reply With Quote
Old 06-17-2007, 06:16 AM   #5
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
did you check your relays?
oowee623 is offline   Reply With Quote
Old 06-17-2007, 06:28 AM   #6
88Tsupra
havent check that yet i wouldnt know how to though
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 06-17-2007, 07:23 AM   #7
oowee623
oowee623's Avatar
when you turn your fog lights on and off do you hear a clicking noise? and the relay i think should be on the junction box near the fog light fuse it will be easier to see when you take off the interior trim covering, but im not sure though cause yours is a 88 and mine is 89, the relay might not even be the problem, could be a bad ground or loose connections. by the way yellow fog lights look pretty sexy on the mk3.
Old 06-17-2007, 06:06 PM   #8
88Tsupra
yeah i hear clicks when i switch it im thinking its a ground wire too but then again it only happend after i put in the HID lights ill check it all on monday
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 06-17-2007, 08:43 PM   #9
oowee623
oowee623's Avatar
if you think that the HID is the problem try putting back the stock headlights and see if it works
Old 06-18-2007, 03:16 AM   #10
88Tsupra
done that still didnt work took both off so now i just think its ground
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
turbo or not ??? That's the question ... sausa MKIV Supra 7 03-30-2007 02:22 AM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
