Old 06-16-2007, 01:31 AM   #1
canadian mole
canadian mole is on a distinguished road
Default PLEASE help newbee with engine rebuild
Hello all I am new to this forum and new to supra's, having had a mid life crises I went and bought one today and would like some advice. I bought a 89 turbo with a blown engine as it seems is popular with these cars from what I have read on this forum and I am going to rebuild it. Now my question is that with the parts below that are on the car and what came with the car what is the best way to rebuild this engine so that it will take the extra hp and avoid engine problems in the future
The car came with the following installed:
550cc Injectors
adjustable fuel pressure regulator
k&n intake
Spec stage 3 clutch
boost controller
HKS AFR fuel computer
Boost & EGT Gauges
3" exhaust
Extra parts:
SPG1GT Turbo by Sound Performance
3" intercooler
Walboro fuel pump
HKS blow off valve
Lexus AFM air/fuel mointor
from taking to the old owner the engine has a loud knock between 2500 and 3500 rpm. I did not even start the car as I do not want to do any further damage.
Any advice from the best way to pull the engine to what I should make sure to upgrade while apart or add would be a big help. I want to end up with a reliable car that is fun to drive and a little more HP than the car beside me. Thanks for all your help in advance and I apoligize if any of the above sounds funny as I just copied what the Guy who sold it to me listed. I got what I thought was a great deal on the car as is and I have always wanted to rebuild an engine (mid life crisis) and am looking forward to this project call me crazy.
Thanks
canadian mole is offline   Reply With Quote
Old 06-16-2007, 05:52 AM   #2
Well, if the engine's got a knock, pull it. I'd probably start with the bottom end. Pull the oil pan and inspect the bearing clearances... depending on how bad it is you may spot it right away.
I highly recommend that you locate amd make good friends with a knowledgable MKIII owner in your area who has done a rebuild before. Forums are great for some types of support, but they're no comparison to having someone who knows exactly what they're doing looking over your shoulder.
Old 06-16-2007, 07:13 AM   #3
tone loc
tone loc's Avatar
and what ever happens a very important mod to handle any upgrades is a metal head gasket and arp head studs
Old 06-17-2007, 12:38 AM   #4
supramacist
supramacist's Avatar
Looks like you cats have this one sorted out so I'm just gonna say. Welcome.
Old 06-17-2007, 01:01 AM   #5
carfanatic89
carfanatic89's Avatar
I had the same with mine. I bought it and 1 month later it started knocking. It wasthe rod bearings. If it is them in your case then pull the engine and check them make sure the rod bearing caps in the right place,where you pulled them off from. check the main bearing too. Befor you put the new rod bearings on make sure there are no groves in the crank. Make sure you put the caps back in the orignal place they cam from
Bottom end rebuild or replace engine ? lensosupra MKIII Supra 3 05-06-2008 12:19 AM
7MGE Engine Rebuild SilenceboneSupra MKIII Supra 1 10-23-2007 06:45 PM
Need help! Trouble after engine rebuild joebuffalo MKIII Supra 1 04-29-2007 09:54 PM
1988 supra engine rebuild 1988Suprakid MKIII Supra 5 06-07-2006 09:07 PM
New Engine Or Rebuild Help ! ! ! ! ! DarkRaiderz MKIII Supra 5 01-23-2006 01:21 AM
