Old 06-17-2007, 08:54 AM   #1
Stanmk3
Stanmk3 is on a distinguished road
Like this one http://cgi.ebay.com/ebaymotors/MAF-T...QQcmdZViewItem ?
I already have the 3.5" lexus afm.Is there anything else i would need for the maft pro to work? sensors etc?
Stanmk3 is offline   Reply With Quote
Old 06-17-2007, 09:18 AM   #2
Yes, like that one. Actually, the seller in that auction is Dr. Jonez. He's a very active member in the MKIII community and is largely to thank for the MAFT Pro supporting our car (he worked directly with the people who make it), and is an official vendor.
From what I recall, the Lexus AFM housing isn't 3.5" (90mm) and has a lot more restriction than even a 3" GM MAF. GM MAF's are inexpensive, less restrictive and a lot more durable than the MKIII Turbo's Karmen Vortex AFM.
(Didn't I cover all of this in that thread I gave you the link to?)
If you want to be able to use the Boost Control feature you need to go with a speed/density setup. This system uses a manifold pressure sensor and a temperature sensor to calculate the amount of air entering the engine. The pressure sensor is required by the boost control software.
You can use the MAFT Pro with stock MKIII Turbo electronics (using the Lexus AFM in the MKIII still requires you to swap in the stock sensors from your original AFM). In this setup it acts like a fuel controller and timing controller... but I don't think it supports boost control. I may be wrong, but I'm pretty sure that at least for now boost control ONLY works with a speed density setup. Besides, switching to either a huge MAF or going to a speed/density setup is a big step up.
If you're comfortable with the Lex AFM mod and doen't want to have to play around with all the settings to get the car running like a champ then stick with the SAFC II.
As with any piggyback, it is STRONGLY advised that you get a wideband 02 controller and sensor to track your air to fuel mixture... one of the easiest ways to kill a perfectly good engine is by tuning blindly.
If you do want to look into the MAFT Pro further shoot me a PM and I can help you track down wiring diagrams and writeups.
By the way, I have a N/A MKIII (actually, the only N/A MKIII running the MAFT Pro... for now). It's a rather different setup than the setup on Turbo MKIII's. I am currently running a 3.5" GM MAF, but I intend on switching to speed/density both so I can do another writeup for the N/A owners out there and to get ready for when I have the time to bolt on my turbo.
EDIT: Oh, as for additional items needed: It depends on the setup you decide is right for you. If you decide to speed density you'll need a MAP sensor (pressure) and an IAT sensor (temp.) and a wire harness (which you could make yourself if you feel up to it. If you want to go MAF then you just need a GM MAF and a wire harness. For the boost control again a harness and a specific vacuum solenoid. If you just want to use the fuel tuning with your existing setup then all you need is the MAFT Pro and the included wiring.
Old 06-17-2007, 04:20 PM   #3
Stanmk3
Actually ive never heard of the GM MAF before you mentioned it.Found a few on ebay.This is what youre talking about right?
http://cgi.ebay.com/ebaymotors/gm-ma...ayphotohosting
or
http://cgi.ebay.com/ebaymotors/3-5-G...spagenameZWDVW
As for boost control i got a blitz solenoid controller installed already
Is there any specific features you would get with the maft pro speed/density setup compared to just using my blitz to controll the boost?
As for other mods,heres a list so you know what i got:
-Reworked botton end w/ Wiseco std size pistons,Eagle rods(not here until august so will use std rods for now),Arp and clevite33 all around,Toga oil pump
-Ported and polished head (being done as we speak) w/ std cams
-Cometic 2.0mm steel head gasket
-A1000 fuel pres regulator
-Walbro 255
-680cc low imp injectors from fiveomotorsport..not sure what make these are as i havent recieved em yet.Anyway quality was garanteed
-AEM Wideband controller w/ 02 sensor
-Other gauges like fuel pressure,boost etc
-RPS stage 3 clutch - 6 puck w/ new bearing kit
-Greddy timing belt
-3" Custom stainless steel exhaust
-Blitz solenoid dual stage boost controller
And lots of other bits and pieces that dont really apply to the engine build
and probably a few that i forgot to mention
Old 06-18-2007, 12:51 AM   #4
ethan12510
ethan12510 is on a distinguished road
so you can my that gm maf and it will work in place of our MAf?
ethan12510 is offline   Reply With Quote
Old 06-18-2007, 04:42 AM   #5
A couple basics here. MAF is a term specific to certain types of air flow meters. The generic term used by Toyota and a few other companies is AFM. The MKIII does not have a MAF. The turbo model has a KV AFM and the non-turbo has a VAF.
Thanks to the MAFT Pro, I do have a MAF in my N/A.
Stan, given everything you've got in your build already I would personally probably choose to go with a speed density setup. Either will work fine though. Yes, those are the type of MAF I'm referring to, although removing the screen isn't recommended. The screen serves one more function than that seller mentions, it makes sure that the air flowing through the sensor is evenly distributed. If the MAF were placed right after a bend in the pipe a lot of air would slip by that the hot wires don't see.... then you run lean, possibly VERY lean.
I just got back from test driving the turbo MKIII I've been setting up for speed/density... WOW. I love that car, too bad I won't have for more than another week.
It's not a horrible system to setup, but it's easy to get intimidated by it.
Flowrate of the Stock Water Pump? Bolarbag MKIV Supra 5 06-03-2008 09:26 PM
