#1 |
My 86.5 Supra seams to have a bit of trouble with water getting into the boot via the lift back. Did the Later MkIII's Have better liftback seals and can they be fitted to the 86.5?
#2 |
7M POWAH! ;)
to be honest i really wouldn't bother with changing hatches etc
generally the leaks come in 3 places... bottom windscreen trim... it bolts on.. you will find the nuts under the boot trim in the hatch.. rip it off and re silicon it all rear windscreen wiper... pull it out dump loads of silicon in there... wack her back in and make sure she's tight tailights... pull em off and re silicon around the seals (if they're still there and not mushed away) or just silicon the car where the taillights bolt in... practically a squarish type shape and you should be fine after that... other than that i can't think of anywhere else it might be leaking good luck with the leak ![]()
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
Leaky top | mister | MKIII Supra | 1 | 12-16-2008 02:47 AM |
leaky targa | silver98Supra | Exterior , Interior, and Detailing | 0 | 06-25-2008 05:05 AM |
Fighting the Dreaded Leaky Hatch | Lunch2000 | Non-Generation Specific Questions | 12 | 08-27-2006 10:08 PM |
Leaky Sunroof | Fuel | Non-Generation Specific Questions | 2 | 04-14-2006 01:52 PM |
Leaky Sunroof | scruffboy | Non-Generation Specific Questions | 0 | 11-22-2005 12:34 PM |
