Old 06-21-2007, 03:30 AM   #1
supradrift
supradrift is on a distinguished road
Default turbo question
what upgrades would be needed if i put a t-66 turbo on my 87 supra 7m-gte running it at about 10 lbs of boost? for example the fuel upgrades, what i would need to tune it, and manifold recommendation
now out of school and want my car fast now that im making some money thanks for any help
supradrift is offline   Reply With Quote
Old 06-21-2007, 03:38 AM   #2
west_side_supra
west_side_supra's Avatar
well from what i was told the stock manifold isnt very restrictive and can handle loads of boost. so i dont think you need to do anything with that. and if i know this question good enough. i think you would be fine with the stock fuel system being that your only doing 10lbs of boost, but if you want to go higher than that. you'll need HG, Fuel, and air "filter/intercooler/Hard pipes" there is probably more im just not awake enough to tell you it all, plus im not as smart as all these other supra guys
7MGTE - 500hp never dyno'd
fidenza cam gears
Turbo lag question. rnoswal MKIII Supra 6 02-12-2006 05:42 AM
