-   -   power steering (http://www.toyota-supra.info/forums/mkiii-supra/8827-power-steering.html)
zuni 06-22-2007 02:27 AM
power steering
i have a leak in one of my power steering hoses. does anyone have a diagram of which lines are which cause i know the hose that is leaking but i dont know what hose i need to replace if that makes sence. i dont know what hose to ask for so i need a diagram of the powersteering so i know what to ask for at the parts store.
supradaddy0803 06-22-2007 02:33 AM
Well a good way to tell is the banjo fitting ones are uaually pressure and the ones with spring clamps on them are return. If it is on te rack itself the top one is the return and the bottom is the pressure. I hope that helps. Also the hoses pass under the car from one side to the other because of the location of the pump to the steering box. Just follow them back to the pump from the top and bottom one on the rack and you will find out which one it is.
zuni 06-22-2007 02:37 AM
theres 2 hoses that look the same and they go under the car and connect to the gear box on the drivers side. the one i need to replace is the one closest to the front of the car. on my set up theres one in front of the other connceted to the gear box. the one i need to replace is closest to the front of the car
both lines look the same though.
