Old 06-22-2007, 03:28 PM   #1
ethan12510
ethan12510 is on a distinguished road
Default thermostat
im replaceing my thermostat and i have got into it and taken the old one out. now do i just lace the new one in? and is there anything specail need to do? Help asap!!!
ethan12510 is offline   Reply With Quote
Old 06-22-2007, 06:29 PM   #2
supradaddy0803
supradaddy0803's Avatar
Giggle valve thing goes to the top, put the o ring around it, and pop it in. no biggy besides that get it tight though dont wanna leak from there.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
Old 06-22-2007, 06:59 PM   #3
plaaya69
plaaya69's Avatar
^ What he said. Also what ever you do becareful when you take the 2 bolts from the water neck because they can break very easy. I had one break on me and the other one almost broke on me.
Old 06-22-2007, 10:13 PM   #4
IHateHacks
IHateHacks's Avatar
And don't tighten those 2 10mm bolts too tight, you can strip the threads out of the aluminum and you'll be helicoiling it.
I think the spec is like 80in/lbs. Maybe 86in/lbs. That's about 7ft/lbs.
Old 06-25-2007, 10:45 AM   #5
Cool
got an overheating problem ?
Old 06-25-2007, 10:29 PM   #6
kidsusukigsxr
kidsusukigsxr is on a distinguished road
Smile Oil Leak Question
I have had this oil leak for sometime now and can't seem to find it. Can anyone tell me where it could possiably be leaking oil from. If your facing the car and your standing in front of it most of my leak coming from the left side of the car and down the front. its gotta so bad it leak into my timing belt and cause it to snap.I have the front completly off and about to put in a new timing belt, but i need to find and fix the leak first. Any help would be apreciated it.
Thank you
kidsusukigsxr is offline   Reply With Quote
Old 06-26-2007, 01:23 AM   #7
j3pz
Thank you
hmm when you have question of your own, it best to start your own thread. also, its very difficult for US to help find an oil leak. your best bet is to follow the leak up to where it start, wipe it up and look for cracks. i dont know if there is much more you can do as far as the internet and leaks go, but start a new thread and maybe you will get more attention and more answers
Old 06-26-2007, 02:22 AM   #8
ethan12510
no not really just i was told that i could use a new thermostat awhile back when i had work done and the other day my them gague went all crazy and went up and down so i got a new on installed it the way i thought it should go and then you guys reasheared me that i did it right so i left it be and now i have no problems!!
Old 06-28-2007, 01:40 PM   #9
Cool kidsusukigsxr
quick reply:
the cam seals
installing thermostat sd88supra MKIII Supra 8 06-18-2010 02:23 AM
Which Thermostat? scruffboy Non-Generation Specific Questions 4 03-01-2007 11:18 AM
Thermostat Necessary? Bullz_EyE MKIII Supra 16 01-02-2007 12:12 AM
Checking Thermostat scruffboy Non-Generation Specific Questions 6 03-09-2006 05:49 PM
Thermostat??? kewlcoconut MKIII Supra 2 12-24-2005 08:37 PM
