Old 06-24-2007, 03:31 PM   #1
curtismoff
curtismoff is on a distinguished road
Default A/C question
I have a 90 NA the air worked great untill yesterday,the clock quit the same time.The switch in the cilmite control seems to work,it still turns on the cooling fans(radiator) but won't engage the clutch.I put a volt meter on the a/c plug no voltage.When I put 12 volts to it the clutch engages.I have checked all the fuses yes even the one on the passenger side for the a/c they are all good.Would I risk damaging something if I wired the compresser to 12 volts with a toogle switch,or is there something I am missing?
Please Help!
curtismoff is offline   Reply With Quote
Old 06-24-2007, 04:22 PM   #2
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
Check the C/B near the 10A A/C fuse. and dont wire it the way you wanted to because their is too many sensors that the a/c compressor runs off of.
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Old 06-24-2007, 06:25 PM   #3
supramacist
supramacist's Avatar
Do an ac delete and save yourself the headaches.
Old 06-24-2007, 06:36 PM   #4
curtismoff
You must be crazy!I live in florida right now it's 95 outside
Old 06-24-2007, 07:41 PM   #5
supramacist
Pull it all out and roll your windows down.
It's 95 degreeas outside, here as well.
Old 06-24-2007, 08:29 PM   #6
curtismoff
No thanks.I would not drive a car that didn't have a/c unless it was a classic with balls and we all know here the NA supra has none!
Old 06-24-2007, 09:58 PM   #7
supramacist
Maybe you just don't have the rest of your car set up. I mean no balls is a steretypical statement and some of our na/s DO have testicular fortitude.
Thank you very much.
Thae ac weight reduces by 50lbs then the back seat delete. But ofcourse those things are your call I was just offering suggestions.
Old 06-26-2007, 07:51 PM   #8
Staceman
Staceman is on a distinguished road
If you are outta freon, the clutch on the compressor will not engage.
Staceman is offline   Reply With Quote
Old 06-26-2007, 08:05 PM   #9
supramacist
YOu can charge it yourself if you use r-134a. You can get the kit and the spray at your local parts store. That will atleast tell you what's up if that's the case.
I was just giving you a hard time about deleting your system.
Old 06-27-2007, 06:14 PM   #10
OfnaRcR
OfnaRcR is on a distinguished road
Not always but that is probally it. It could be a low pressure cut off switch problem.
OfnaRcR is offline   Reply With Quote
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
