Old 06-26-2007, 09:40 PM   #1
Supra86
Supra86 is on a distinguished road
Default Head Gasket
Is there any way to fix the haed gasket problem on the 7mge motor so it does not happen again
Supra86 is offline   Reply With Quote
Old 06-26-2007, 10:02 PM   #2
motosparky
motosparky is on a distinguished road
INSTALL A 1JZ
Sorry, but I have done one on all my 7MGE's and Turbos.
It is that damn # 6 cylinder/water jacket wall being to thin.
89 N/A Supra
Previous:
90 Turbo
86.5 N/A
85 GT
http://s81.photobucket.com/albums/j2...%20For%20Sale/
motosparky is offline   Reply With Quote
Old 06-27-2007, 01:03 AM   #3
IHateHacks
IHateHacks's Avatar
Proper prep work done to the head and block, ARP hardware (bolts or studs), a digital torque wrench, and following the tighening sequence that's in the TSRM will keep it from blowing again. I did mine in 5 passes, the TSRM recommends 3.
Old 06-27-2007, 02:31 AM   #4
SupraDupra
SupraDupra's Avatar
Agree. The only reason the head gaskgets fail is because the factory had improper torque specs. Do it right ,do it once
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 06-27-2007, 05:13 AM   #5
supramacist
supramacist's Avatar
I did mine in 5 passes as well.
Kobalt torque wrench. Took them to 85flbs.
Yes you can do the hg thing and do it so it doesn't do it again. I honestly doon't think their is any real gaurantee.
Old 06-27-2007, 07:32 AM   #6
tone loc
tone loc's Avatar
i hear its because of unproper torque from the factory.
Old 06-27-2007, 08:33 AM   #7
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
i heard somwhere that i was originally made of asbestos then then changed the material and not the torque
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 06-27-2007, 10:00 PM   #8
supramacist
Well atleast we are all hearing the same crap.
Old 06-27-2007, 11:43 PM   #9
IHateHacks
IHateHacks's Avatar
Shit I forgot to list the most important part, torqueing higher than 58ft/lbs! But thats pretty much a given. I was just listing the things that will improve your chances of not having to do it AGAIN!
I took my ARP bolts to 70ft/lbs. She sees redline everyday, hasn't used a drop of coolant, never overheats, really never gets hotter than 200 degrees even on a 95 degree day while driving it retarded.
Old 06-27-2007, 11:49 PM   #10
supramacist
Man it's going to be a pita to retorque those studs.
Blown Head Gasket Snake Oil unkymurch Non-Generation Specific Questions 21 08-06-2010 02:11 AM
Head Gasket Part II Bullz_EyE MKIII Supra 2 01-26-2006 06:30 PM
