Old 06-28-2007, 08:44 AM   #1
igosaur
igosaur's Avatar
igosaur is on a distinguished road
Default Brake Fluid Reservoir
I have a slight leak in one of the grommets/seals that connect the brake fluid reservoir to the cylinder body.
This means that I have to top up with brake fluid every now and then to bring it back up to the max level.
Is this dangerous or just a bit annoying? The brakes themselves seem fine.
Is it possible that the reservoir has just become a little loose and needs tightening?
As I'm about to undertake a long journey it would be nice to know that the brakes won't suddenly fail and I won't end up in a crumpled Supra by the side of the road
Last edited by igosaur; 06-28-2007 at 08:51 AM. Reason: Just thought of something else to ask :)
igosaur is offline   Reply With Quote
Old 06-28-2007, 10:52 AM   #2
SupraDupra
SupraDupra's Avatar
Most of the cars I have owned have had that problem. I just keep adding fluid because there are so many other problems I put ahead of rebuilding the brake booster. Just adding fluid is lazy/annoying ,but I would not call it "unsafe". As long as it's a slow enough leak that air isn't sneaking into the system on you ,it would be my opinion that you can put off the repair for a bit.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 06-28-2007, 10:55 AM   #3
igosaur
igosaur's Avatar
Thanks for that. That's put my mind at rest
I changed the rear brake pads a while ago (first time job for me) and thought I might have mucked something up..
Brake Fluid Dot 3 or 5.1 colin172 MKIII Supra 6 10-17-2007 10:44 PM
losing brake fluid oowee623 MKIII Supra 3 08-07-2007 04:44 PM
Maintenance brake and clutch master cylinder fluid IHateHacks MKIII Supra 1 04-18-2007 07:15 PM
Wilwood MKIII Rear brake kit ARZ Arizona Performance 0 03-16-2007 07:46 AM
