Old 06-28-2007, 06:44 PM   #1
ethan12510
ethan12510 is on a distinguished road
Default Whats ur supra sound like???
well when i drive my car slow like under 20 mph i hear a kind of draging noise coming from the back end of my car. but it dosent make thaat noise when i am going faster and turn? i dont know if it has something to do with the LSD. I dont know if its normal or if its something i need to fix. thanks
ethan12510 is offline   Reply With Quote
Old 06-29-2007, 07:48 AM   #2
It's not normal. It could be bearings, either in the differential, the wheel knuckles or the carrier bearing. Typically a bad carrier bearing is accompanied by vibration when driving at high speeds. Also check to make sure it isn't just a brake pad that's sticking to the rotor or a problem with the e-brake.
Old 06-30-2007, 03:25 AM   #3
ethan12510
well when i pull on the e brake it goes away.
Old 06-30-2007, 03:41 AM   #4
Well, it could still be a couple different things, but you might want to pull the rotors and check for signs of damage, loose parts, sticking pads or even just a ton of old brake dust.
Found Supra does this sound resonable? Jbone7 Non-Generation Specific Questions 1 01-18-2008 04:01 PM
