Old 06-29-2007, 06:01 PM   #11
D_Train
D_Train is on a distinguished road
Originally Posted by f00g00
Check the piping on the back of the block, one side has the heater hose and the other is plugged with a little rubber nipple and clamp. I had a slow leak that finally showed up when the plug finally blew, then I finally saw it as I was pouring water in the rad on the side of the road!
Chances are the water thats leaking out is evaporating on the back of the block or dripping down the transmission. You should be able to see some old staining there if thats where its leaking from. You can stick your hand back there when its cold and squeeze the hose or plug and you should get your hand wet if thats where its leaking.
The piping is designed for LHD and RHD due to locations of the heater valve on the firewall thats why one side has a plug.
hehe. nipple.
on a serious note thanks for the tip. I'll check it out :-D
D_Train is offline   Reply With Quote
Old 06-29-2007, 08:56 PM   #12
supramacist
supramacist's Avatar
I may be wrong but wouldn't anti-freeze show up under a black light??
Or would it just go dark? Anyhow get the black light dye. Add it to the rad and go for a drive. Cruise the car wash and spray the under carriage. Get it clean and don't do anything until it's time to fill it up. Don't fill it. Wait for dark and hit it with the black light. Don't use the bulb. You need the flourescent.
Old 06-30-2007, 10:20 PM   #13
supradrift
supradrift is on a distinguished road
same leak happened on mine it started off small i couldnt find where it was coming from so i kept driving and filling it up then on my way to a car show the thing exploded and was pouring all over the exhaust.
supradrift is offline   Reply With Quote
Old 07-01-2007, 09:28 PM   #14
supramacist
AHHHH, the smell of burning coolant.
It's right up there with WD40.
Old 07-03-2007, 05:35 PM   #15
D_Train
Originally Posted by rinso
I a similar problem when I first bought my supra. Turned out to be the radiator cap, the dealership I bought it from put the wrong cap on and my coolent got up and disappeared, though there was a fair bit of overheating involved with that while the car wasn't in motion.
Yah, but I had them put it through a pressure test, don't you think they would have noticed something?
Old 07-11-2007, 03:56 AM   #16
rinso
rinso's Avatar
rinso is on a distinguished road
They definately would have noticed something out of whack. I guess your problems lay elsewhere!
rinso is offline   Reply With Quote
Can anyone point me in the right direction on my boost? fienloco Non-Generation Specific Questions 9 09-07-2008 09:42 AM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
