Old 06-28-2007, 07:17 PM   #1
D_Train
Default angered at this point
So I had a shop (dealer) do a test for a BHG and they found nothing. I made sure they did a block test as well and they said when they test they do three different tests, bla bla bla. anyway, i'm still loosing coolant. Not overheating, no white smoke out the back, no smells, no milky oil. I have no clue where its going...
Old 06-28-2007, 07:55 PM   #2
Supra2NR
Supra2NR's Avatar
probly a really small hole or crack in one of your radiator hoses?
check both the upper and lower radiator hose
check the resorvoir bottle for leaks too,
check the cap,
any coolant on the radiator itself?
any visible leaks underneath the engine?
Old 06-28-2007, 08:09 PM   #3
88Tsupra
like supra said could just be a leak mines is doing the same check underneath the car or warm up the car and look for leaks that way theres some pressure dats how i found my massive life..it was the hose that connected to the manifold
88turbo targa-white
original Pin Stripe
NGK plug and wires
HID conversion head lights
Tial BOV
BIC DDP
Old 06-28-2007, 09:30 PM   #4
D_Train
yah, its just wierd because no matter where I am it will not leave ANY residue on the ground. I'll try to look soon, but i dunno
Old 06-29-2007, 03:02 AM   #5
rinso
rinso's Avatar
rinso is on a distinguished road
I a similar problem when I first bought my supra. Turned out to be the radiator cap, the dealership I bought it from put the wrong cap on and my coolent got up and disappeared, though there was a fair bit of overheating involved with that while the car wasn't in motion.
rinso is offline   Reply With Quote
Old 06-29-2007, 03:06 AM   #6
D_Train
should i try some of that "add this to your coolant system to stop leaks" stuff i've seen?
Old 06-29-2007, 03:31 AM   #7
plaaya69
plaaya69's Avatar
Exclamation
^ DO NOT DO THAT! That stuff will make more problems and clog the heater core and that is not good. I seen another thread and someone used that stuff and it made problems for him. Just fix the problem and do not put a patch on it because it will come back later if not done right.
Old 06-29-2007, 03:50 AM   #8
D_Train
of COURSE I want to fix the problem :-D
I just don't know what it is.
Old 06-29-2007, 04:36 AM   #9
88Tsupra
could be what rinso said my radiator cap is going out on me and i have your problem
88turbo targa-white
original Pin Stripe
NGK plug and wires
Tial BOV
BIC DDP
Old 06-29-2007, 03:36 PM   #10
f00g00
Check the piping on the back of the block, one side has the heater hose and the other is plugged with a little rubber nipple and clamp. I had a slow leak that finally showed up when the plug finally blew, then I finally saw it as I was pouring water in the rad on the side of the road!
Chances are the water thats leaking out is evaporating on the back of the block or dripping down the transmission. You should be able to see some old staining there if thats where its leaking from. You can stick your hand back there when its cold and squeeze the hose or plug and you should get your hand wet if thats where its leaking.
The piping is designed for LHD and RHD due to locations of the heater valve on the firewall thats why one side has a plug.
Can anyone point me in the right direction on my boost? fienloco Non-Generation Specific Questions 9 09-07-2008 09:42 AM
6 point Roll Cage? carl johansson Road Racing & Autocross 0 12-01-2007 12:28 AM
