-   -   angered at this point (http://www.toyota-supra.info/forums/mkiii-supra/8896-angered-at-this-point.html)
D_Train 06-28-2007 07:17 PM
So I had a shop (dealer) do a test for a BHG and they found nothing. I made sure they did a block test as well and they said when they test they do three different tests, bla bla bla. anyway, i'm still loosing coolant. Not overheating, no white smoke out the back, no smells, no milky oil. I have no clue where its going...
Supra2NR 06-28-2007 07:55 PM
probly a really small hole or crack in one of your radiator hoses?
check both the upper and lower radiator hose
check the resorvoir bottle for leaks too,
check the cap,
any coolant on the radiator itself?
any visible leaks underneath the engine?
88Tsupra 06-28-2007 08:09 PM
like supra said could just be a leak mines is doing the same check underneath the car or warm up the car and look for leaks that way theres some pressure dats how i found my massive life..it was the hose that connected to the manifold
D_Train 06-28-2007 09:30 PM
yah, its just wierd because no matter where I am it will not leave ANY residue on the ground. I'll try to look soon, but i dunno
rinso 06-29-2007 03:02 AM
I a similar problem when I first bought my supra. Turned out to be the radiator cap, the dealership I bought it from put the wrong cap on and my coolent got up and disappeared, though there was a fair bit of overheating involved with that while the car wasn't in motion.
D_Train 06-29-2007 03:06 AM
should i try some of that "add this to your coolant system to stop leaks" stuff i've seen?
plaaya69 06-29-2007 03:31 AM
^ DO NOT DO THAT! That stuff will make more problems and clog the heater core and that is not good. I seen another thread and someone used that stuff and it made problems for him. Just fix the problem and do not put a patch on it because it will come back later if not done right.
D_Train 06-29-2007 03:50 AM
of COURSE I want to fix the problem :-D
I just don't know what it is.
88Tsupra 06-29-2007 04:36 AM
could be what rinso said my radiator cap is going out on me and i have your problem
f00g00 06-29-2007 03:36 PM
Check the piping on the back of the block, one side has the heater hose and the other is plugged with a little rubber nipple and clamp. I had a slow leak that finally showed up when the plug finally blew, then I finally saw it as I was pouring water in the rad on the side of the road!
Chances are the water thats leaking out is evaporating on the back of the block or dripping down the transmission. You should be able to see some old staining there if thats where its leaking from. You can stick your hand back there when its cold and squeeze the hose or plug and you should get your hand wet if thats where its leaking.
The piping is designed for LHD and RHD due to locations of the heater valve on the firewall thats why one side has a plug.
