Old 06-24-2007, 03:31 PM   #1
curtismoff
curtismoff is on a distinguished road
Default A/C question
I have a 90 NA the air worked great untill yesterday,the clock quit the same time.The switch in the cilmite control seems to work,it still turns on the cooling fans(radiator) but won't engage the clutch.I put a volt meter on the a/c plug no voltage.When I put 12 volts to it the clutch engages.I have checked all the fuses yes even the one on the passenger side for the a/c they are all good.Would I risk damaging something if I wired the compresser to 12 volts with a toogle switch,or is there something I am missing?
Please Help!
curtismoff is offline   Reply With Quote
Question about 7m-gte. AzNbOi2626 MKIII Supra 3 03-29-2011 06:55 PM
Starter Removal question OkieRA29 MKIII Supra 13 05-11-2010 12:08 AM
Pre89 versus 89+ nose and support. lifesnotfair MKIII Supra 2 01-08-2010 09:06 PM
Help! Question on front NOSE and bumper supports. lifesnotfair MKIII Supra 1 12-26-2005 03:54 PM
Quick question AutoXMan MKIII Supra 12 09-30-2005 06:40 AM
