#1 |
hey there, my friend and i are trying to instal a manual boost contoller (ball and spring) so that he will boost more. i thought i would register really quickly on this forum so ask a few questions.
1. according to the gauge we hooked up last night stock boost is 6psi? is this right? 2. what is a safe amount of boost we can run? i was thinking 10psi. his car is completley stock 3. will i need to disable the boost selenoid? is there even one. there was one on my old mazda that i had to unhook. i know absolutly nothing about supras, but have a fair bit of knowledge when it comes to FI. 4. is there a guide to hook up this contoller because i have the boost controller set at 10psi from my old mazda and its still only boosting 6. thanks |
#2 |
replying to this post may be too late
however i want to warn you: appling more boost without planning will result in a blown head gasket before you know it . and btw a manual controller is fun at first but you'll find boost levels ranging all over the place using a stock boost gauge is not a good idea it only goes up to like 8 doesn't it ? once you start getting fuel cut off you might want to back off a little . atleast until you have an accurate measurement of boost
300+ RW HP Dyno run, jdm,mod turbo,3"exh,electfan,greddyboost Blown HeadGasket info My Supra KiXGaS |
#3 | |
![]() Quote:
#4 |
SP58GT
6-7 is stock 11 is the safety point. fuel cuts at 12 and turbo runs out o' power at 14. i put a ball and spring in mine and she started to act strange.
....all you need is a small taste of success and you will find it suits you.... monique- better off dead ![]() |
#5 |
7M POWAH! ;)
sometimes you may have to turn up the boost controller a little more than usual... they differ on different cars
what sort of boost controller are you using?
Please use the forum to ask your questions as they will get replied to much faster than pming me ![]() Pics of my build. "Good girls are just bad girls that don't get caught" ![]() Do a diagnostic first! |
Thread Tools | |
Display Modes | |
manual boost controller | tak2099 | MKIII Supra | 5 | 11-23-2009 11:47 PM |
HELP PLEASE | Nick0887 | Non-Generation Specific Questions | 4 | 02-28-2009 07:26 AM |
Manual Boost Controller and Turbo timmer question | ethan12510 | MKIII Supra | 5 | 02-20-2008 10:54 PM |
manual boost controller!!!!!!! | justin1642 | MKIII Supra | 6 | 01-16-2007 10:01 PM |
