Old 07-05-2007, 03:23 AM   #1
A couple things could cause a piston to move freely like that... none of them are really good. A broken rod, broken wrist pin (although in this case the rod would still push the piston back up), broken cap screws. And yes you can break a rod without it going through the block.
As for how rebuildable it may be, you won't know until you open up the bottom end.
Junkyard engines can cost you anything from $100 to $500. That really depends on the yard and if they know anything about engines.
Old 07-06-2007, 08:09 AM   #2
carfanatic89
carfanatic89's Avatar
carfanatic89 is on a distinguished road
I bought my 7MGE (my old block was cracked)from a japan import place 40,000 miles on it, 4 month warranty, or 4000 miles. Complete engine and accessories for $913.
carfanatic89 is offline   Reply With Quote
ABS Problem? rasclaat_98 MKIII Supra 6 12-13-2010 09:53 PM
found the problem brs86supra MKIII Supra 0 05-02-2006 03:42 PM
Boost Problem, I Guess nonstop213 MKIII Supra 0 02-23-2006 07:32 PM
tsp problem for na t supra jdlee123 MKIV Supra 0 09-02-2005 06:01 PM
