Old 07-08-2007, 09:17 PM   #11
SupraDupra
SupraDupra's Avatar
I doubt anyone took you as hostile. We all know the frustration when you get so close but can't clear that last hurdle. Before you run out and buy a new MAF box I would recomend you get those diagnostic codes. Double check the vaccume lines for leaks ,check that your timing belt in installed to correct tollerance ,and the distributor is properly set.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 07-08-2007, 10:55 PM   #12
supramacist
supramacist's Avatar
31 afm sensor
24 intake air temp signal
Is it me or are these signs all pointing to the maf???
The air temp sensor plugs into the under side of the accordian tube, yes?
If that's that, I know what's up with it.
I still don't know crap about the afm. I was even calling it the maf.
I have clearly been in the garage waaaaaaay too long with this one.
I have built my own, incorrect vocabulary.
I'll try and not type so messily in the future, I read back.
I hate typos.
Old 07-09-2007, 04:57 AM   #13
SupraDupra
SupraDupra's Avatar
Originally Posted by supramacist
...Is it me or are these signs all pointing to the maf???
...I still don't know crap about the afm. I was even calling it the maf....
You're still doing it. You even had me ,at least we all knew what we meant. I just have a hard time seeing the AFM randomly going bad. I would like to see some more opinions. Where is nickleye when you need him?
1974 'Cuda - 318
2001 Cherokee
Old 07-09-2007, 06:32 AM   #14
supramacist
LOL. You know those old cats need there rest.
I guess I'll buy a remand and keep mine unless they need it as a core.
It's priced at o"riellys at 175.
I wonder if I can get some kind of rebuild kit???
EDIT: I wouldn't ask all of this but my dealership is closed today.
I really appreciate it supra dupra. LOL that was one I thought of until I was hit by supramacist. I'm rambling.
Thanks again.
Old 07-09-2007, 12:01 PM   #15
IHateHacks
IHateHacks's Avatar
Did you drop the AFM while you had it off during the build? Did you drop something on the AFM?
Old 07-09-2007, 05:01 PM   #16
supramacist
Nothing like that. It was secure and out of the way.
Old 07-09-2007, 11:57 PM   #17
Test the AFM per the TSRM: http://www.cygnusx1.net/Supra/Librar...ection=FI&P=94
Then if that all checks out test lines E2 and VS from the AFM harness connector to the ECU connector for excessive resistance.
Old 07-10-2007, 04:52 AM   #18
supramacist
Thank You CRE.
Why does my tsrm not have this in it???? Anyone.
Old 07-10-2007, 07:17 AM   #19
Thank You CRE.
No problem and no idea, my '88 TSRM has it. It's in the EFI section.
Old 07-10-2007, 11:38 AM   #20
IHateHacks
IHateHacks's Avatar
Yeah it's in my 87 TSRM.
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
Supra time? furia MKIII Supra 11 08-28-2007 01:19 AM
One more time, my air removal method. Monkey Non-Generation Specific Questions 2 04-20-2007 02:09 AM
0-60 time f00g00 MKIII Supra 16 08-09-2005 05:53 PM
