Old 07-08-2007, 01:39 AM   #1
supramacist
supramacist's Avatar
Default Alrighty Fella's..., 1 more time
Alright. I got my 91 up and running today. I let it idle and found 1 hose I missed a clamp on. I had to kill it to go and get some gas because I only had enough for 1 heat cycle.
Now, I came back and put the gas in and the thing cranks and sounds good.
But...., If I even bump the peddle it will stall out. And now it's start and slowly dies.
It seems like it may be getting too much air, but I am unskilled in this area.
Any comments or direction would be greatly appreciated.
Thanks Gents.
Old 07-08-2007, 02:46 AM   #2
Supra2NR
Supra2NR's Avatar
How high can u rev it?
2k? Maybe the maf,
Or the idle air control hose is pinched or disconnected,
Try checking those first
Old 07-08-2007, 03:59 AM   #3
supramacist
I can rev it to 3.5
When it comes down it catches at 12ish and idles a bit and craps out.
Also while it is reving it kind of snap crackle poppy. If you can follow that.
Edit: upon crank it'll rev just fine a side from the crackle.
It turned over first try and it sounds strong. It didn't sputter or cough.
Old 07-08-2007, 08:46 AM   #4
SupraDupra
SupraDupra's Avatar
What happend before you got to the point you're at now? Did you swap any parts out? I would double check the throttle position sensor and the timing. Sounds like some simple thing is just a little off. Only about 1,000 "simple" things to check
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 07-08-2007, 05:00 PM   #5
supramacist
I know.
I just don't know where to start.
Fuel pressure regulator...., I think all you can do is replace it.
Maf....., I don't know jack about adjusting the thing.
Where I was at before this is the car has been down with a bhg and has recently been replaced. The machine work was done and all of the things like the starter and alternator are all new.
I'm kind of at a loss here. It started this morning and ran long ebough to get up to operating temp and then dies.
If I plug the maf up it kills it.
Do you guys think a need a new fuel pressure regulator or do ya think the problem lies in the maf.
Old 07-08-2007, 05:58 PM   #6
plaaya69
plaaya69's Avatar
plaaya69 is on a distinguished road
Do you have any codes? I also had the same problem with my JDM motor but I had three problems with it. They are
-the AFM was bad(code 31)
-the TPS was no good(code 41)
-the CPS was not installed right
1987 Toyota Supra Turbo-burgundy exterior w/gray interior+1987 Toyota Supra(N/A) light brown top,dark brown bottom w/light brown interior.
plaaya69 is offline   Reply With Quote
Haha.....Read these Emails about SUPRAS FOR SALE Metalluthier Non-Generation Specific Questions 54 04-25-2011 11:51 PM
Supra time? furia MKIII Supra 11 08-28-2007 01:19 AM
One more time, my air removal method. Monkey Non-Generation Specific Questions 2 04-20-2007 02:09 AM
0-60 time f00g00 MKIII Supra 16 08-09-2005 05:53 PM
