Old 07-08-2007, 01:50 AM   #1
IHateHacks
IHateHacks's Avatar
Default Slotted Rotors
Put on slotted rotors yesterday. Only the front, with new organic pads. The rotors came with a sheet of paper telling you how to break the new rotors in and that you must use new pads with these rotors and it also recommends using semi-metallic pads. I couldn't find any store that had semi-metallics in stock only one store had a set of organic pads.
After you take the caliper and bracket off the old rotors come off with a block of wood and a big fuckin hammer. Or if you don't give a shit you can straight hit the rotor with the hammer. Just keep rotating the rotor and hitting it and it will eventually come off.
They look better out of the bag. I was going to paint the calipers and brackets but with the stupid sawblades it would have been pointless. Gotta order stainless steel lines and maybe the rotors for the back.
Old 07-08-2007, 01:57 AM   #2
oowee623
oowee623's Avatar
oowee623 is on a distinguished road
my stock rotors just slid off the studs i find it wierd that you had to bang them out, also post up how to break them in, im interested in reading it cause i just put my slotted rotors in with the same pads.
how much did you pay for it?
mine was $85 a pair from braketech in long beach
89 white package twin turbo
Originally Posted by supradaddy0803
the results of your work will be very nice when you push the gas and hold on for dear life.
oowee623 is offline   Reply With Quote
Old 07-08-2007, 02:03 AM   #3
IHateHacks
IHateHacks's Avatar
The paper is in the car but it tells you to make 10 stops from 35mph and waiting 3-4 minutes until you stop again and thats between each stop. Then after 20 miles you stop from 50mph 3 times but don't fully come to a stop, always keep the car moving. And don't make any "highspeed stops" for 500 miles. Basically you have to heat the rotors up slowly and allow them to cool before you heat them up again. It "tempers" the rotor. Just repeating roughly what the paper says.
Well my rotors were stock 20 years old never replaced. I had a tough time getting the drivers side off, it was a bitch I had to literally smash it off. There is a ridge on the outer most surface of the old rotors, they were pretty bad. I paid $200 shipped for Powerslot rotors. They have some cadmium plating or some shit so they don't rust. The rears are $220 and the lines are $89. I'll be ordering the lines next week.
And slotted rotors are directional, so keep that in mind when installing them. They are labeled on the rotor.
Old 07-08-2007, 02:20 AM   #4
oowee623
oowee623's Avatar
crap when i put them on i went about 65 then braked hard to see how fast they would stop compared to stock, oh well
and yea i knew about slotted being directional, i saw some guy with a navigator that had em on in the wrong direction and i tried telling him but he looked all confused.
and also im wondering since theres such a big price gap between mines and powerslots is there a difference in performance too? or is it just the label?
Old 07-08-2007, 03:30 PM   #5
j3pz
heres mine, i did them earlier this week. got a package from 935motorsports: 4 slotted rotors, ss lines, and pads for like 400. i also painted the calipers.
Old 07-10-2007, 11:30 PM   #6
supra_91
supra_91's Avatar
there are two threaded holes on the rotors where u put a bolt in and tighten them to push them off. that way you dont have to beat them.
Brake Rotors Iodine MKIII Supra 2 02-18-2007 06:04 AM
Need new rotors Reeves MKIII Supra 13 08-30-2006 05:34 PM
Brakes Rotors XtreeX MKIII Supra 1 02-07-2006 12:42 AM
rotors supra_91 Non-Generation Specific Questions 4 11-05-2005 03:54 AM
