Old 07-09-2007, 06:45 AM   #1
kuroi_tuki
kuroi_tuki is on a distinguished road
Unhappy HELP!!!!!!!.....1JZ wont idle!!!!!
Hi! I have a 91 MK3 that i imported from japan which has 1JZ-GTTE. I loved the car, itz completely stock except the trust filter, trust exhaust, and cat bypass.......anway.... this came out of no where. I was driving normally. Next day, when i started the car, it didnt idle, i thought it was because i dont have full fuel, so i filled up the gas, and it still wont idle.........I can drive the car, but I have to step on the gas to keep the engine running, the funny thing is that once the boost goes to 0kg/mm, i can hear a leak the the turbo, but then i disconnect the battery to reset the ECU, then i reconnect the battery n start the car again, it was fine, but itz only the leak is gone, the idle problem still exist........o and one more thing, there r alot of black smoke comin out <--it makes the underground parking lot so foggggggggy........................any1 have any ideas???
kuroi_tuki is offline   Reply With Quote
Old 07-09-2007, 12:41 PM   #2
supradaddy0803
supradaddy0803's Avatar
Mine did the same thing when I got my swap done I forgot to mark all of the vaccum line and it would not idle. Check all of the vaccum lines from the intake and make sure they dont have any leaks. Especially the ones comming from the intake that dont have the vaccum filter on them they will cause it to run rich and die really fast. If you can send a picture of your intake side and I will see if I can tell you if they are all routed right.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
won't idle 3.0trd MKIII Supra 6 06-15-2009 07:23 PM
Wastegate Idle issue... please help Subjug4tor MKIII Supra 9 05-15-2008 01:59 AM
Car doesnt like to idle in the morning XxSupra4LifexX MKIII Supra 11 12-24-2007 07:27 AM
Idle problem 1988 Supra non turbo jimwww Non-Generation Specific Questions 3 01-24-2006 03:50 PM
HELP!!!! '87 Supra idle problem Morpho MKIII Supra 0 10-03-2005 02:40 PM
