Old 07-09-2007, 05:48 PM   #1
go.stfu
go.stfu's Avatar
go.stfu is on a distinguished road
Default 7MGE: Smoke/Mileage/Cold-Start
Hi all,
Have a problem with my n/a:
On a cold-start, the engine will struggle to idle at ~500-600rpm until it warms up a bit and will then idle normally.
Also, on a cold-start, white smoke will come out of the exhaust for 3-4 seconds and then everything will be peachy.
The engine does seem to be burning more oil than it was before and the gas mileage really sucks.
Any suggestions as to what to look into?
Thanks.
1985 manual (r.i.p) -- 1989 automatic (new)
http://www.cardomain.com/ride/2635827
go.stfu is offline   Reply With Quote
Old 07-09-2007, 07:05 PM   #2
SupraDupra
SupraDupra's Avatar
I'm thinking the cold start injector is running on the rich side. When is the last time you did a general tune up? Is the car giving any error codes? A tired oxegen sensor can also give you crappy mileage and throw off the air fuel ratio.
1988 Supra - N/A 5 speed
1974 'Cuda - 318
2001 Cherokee
Old 07-09-2007, 11:53 PM   #3
Personally, I would start with a compression test to make sure the headgasket isn't leaking.
Old 07-10-2007, 12:33 AM   #4
supra_91
supra_91's Avatar
Originally Posted by go.stfu
Hi all,
Thanks.
mine pretty much does the same thing. On cold start it idles rough for a few seconds then evens out (doesnt do it all the time). white smoke will also come out for about 5 seconds
the engine doesnt use any oil and my gas mileage is ok (19-20, it varies once in awhile)
at mid to high rpms it spits and sputters a little bit. i does it more when its cold but it has also done it when its warm. it doesnt do it all the time and it doesnt usually last very long.
i changed the plug wires with NGK's and the plugs were changed a year ago.
what should i do?
Old 07-10-2007, 05:54 PM   #5
go.stfu
go.stfu's Avatar
Thanks for the info. I'll do a compression test and check the sensors when I get around to it. Unfortunately, another potentially expensive problem just popped up. The timing belt is slipping off =/ heh.
Old 07-10-2007, 08:12 PM   #6
supramacist
supramacist's Avatar
Cold start sensor was my first thought.
Old 07-10-2007, 11:24 PM   #7
supra_91
supra_91's Avatar
so your saying its dumping excess fuel into the engine causing it to spit.
is the cold start sensor just a part of the cold start injector or is it the whole thing.
Old 07-11-2007, 01:02 AM   #8
supramacist
I meant to say cold start injector.
I'm sorry.
87 Supra won't start RNEMESiS42 MKIII Supra 3 06-25-2011 06:30 PM
Car wont start hot carfanatic89 MKIII Supra 41 03-30-2009 10:58 PM
Car Died...where to start? Jrew MKIII Supra 4 10-26-2007 02:19 PM
no start 87supraguy MKIII Supra 5 03-23-2006 07:31 AM
Engine still wont start 87 supra 7mge lilsmitty MKIII Supra 12 01-12-2006 10:53 PM
