Old 07-09-2007, 10:40 PM   #1
abhattan
abhattan's Avatar
abhattan is on a distinguished road
Default Desperately Seeking help with Lexus AFM and Injectors!!!
I just installed a set of 550cc/min injectors and a Lexus AFM. Now the car runs like crap. Sounds like a misfire at idle, almost like I have a cam in it, and it sounds like it is misfireing throughout the rpm range. While driving, it misses slightly. No check engine light. When I get on it, It will get to 5lbs normally and then shoot to 9 lbs. What can this be? Please hlep.
'91 Turbo Targa 5 Spd.
'87 Corolla GT-S 5 Spd
'91 Accord Daily Driver 5 Spd
Soon to be rebuilt (All to some extent)
abhattan is offline   Reply With Quote
Old 07-09-2007, 11:22 PM   #2
Which KV sensor is in the Lex AFM? You need to swap in the one from your stock AFM.
Also, what brand of injectors are you running?
Old 07-09-2007, 11:54 PM   #3
abhattan
abhattan's Avatar
I don't know, but I tried it with the stock one on and the lexus unit. Still ran the same way. How can I tell what's what? I heard something about a screw, what is that? As far as the injectors go, I have no idea, but they came off of his car and were fine on his car. He had them cleaned and tested then i got them. All I know, is that I didn't have to use seperate clips.
Old 07-10-2007, 12:13 AM   #4
It sounds like you're running very rich. Do you have a wideband? If so, what are your AFRs looking like?
EDIT: Oh, the screw is used to reduce or increase the amount of unmetered air that's let through the AFM. It's in the side and I think there's normally a cover over it. If you don't have a wideband I wouldn't recommend adjusting it.
Old 07-10-2007, 12:31 AM   #5
abhattan
abhattan's Avatar
I see the screw and didn't touch it. I checked to see if all of the injectors are firing, and they are, also, no codes. Should I have to readjust my timing for this mod or anything I should be doing otherwise? I don't have a wideband by the way.
Old 07-10-2007, 06:33 AM   #6
Well, with no tuning your idle and low power band are going to be pretty rich. Idle will probably be real bad since I don't think the ECU monitors A/F at idle... sorry, it's late and I can't picture the entire scenario or remember all the specifics at the moment. I'll post back if I think of anything else.
Old 07-10-2007, 11:26 AM   #7
ddmcse
ddmcse's Avatar
Cool
there is no screw really you just see the screw head
thats part of your problem . you are most likely lean and getting too much air
this site used to have pictures
http://www.supras.co.uk/resources/Mk...e.htm#Chapter3
the lexuz afm has a large bypass section allowing unmetered air you need to adjust that amount of unmetered air
it would have been good to install an air/fuel meter before so you'd have an idea where your mixture was at before
search google for "reg reimer afm screw "
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
Old 07-10-2007, 09:20 PM   #8
abhattan
abhattan's Avatar
Thanks alot for all of your help.
Old 07-11-2007, 01:07 AM   #9
supramacist
supramacist's Avatar
In the even this doesn't work you can pull the efi fuse and crank the engine to clear the old codes and the use the jumper wire and try codes again.
I know you said you had none but it may be beneficial to clear it and try it again.
Old 07-11-2007, 01:12 AM   #10
abhattan
abhattan's Avatar
I tried that and still nothing. However, I did find out that the injectors were actually a littler bigger than 550cc. Somewhere around 600 or so. This is probably the reason the car is running like crap. But it does seem to be a tad bit better.
